Antialias lines - error
Andreas Albarello andreas.albarello at TERRITORIUMONLINE.COM
Wed Sep 20 16:40:10 EDT 2006
Jennifer,
which version of Mapserver/Mapscript and GD are you using? I've myself
experienced random crashes when trying to use antialiasing with
Mapserver versions prior to 4.8. Besides, back then, even if the map
rendered successfully, antialiasing didn't work.
You should upgrade to the last stable version (4.8.4) at least. You
might even want to try the new 4.10 beta.
Best regards,
Jennifer Strahan wrote:
> Hello,
> I would like to use Antialias for some of my line layers.  It works fine
> for one of my layers (regional trails), but when I use it for another
> layer (highways), I get this error message:  Premature end of script
> headers: /var/www/cgi-bin/php.  If the map extent includes the entire
> highways layer, the map image is generated.  If I try to zoom in, the
> map image is not generated and I get that error.  Here's the layer
> definition in the mapfile:
> LAYER
>   GROUP "Line"
>   NAME "Highways"
>   STATUS ON
>   TYPE LINE
>   DATA Highways_dot
>   TRANSPARENCY alpha
>   CLASS
>     NAME "Highways"
>     STYLE
>        WIDTH 1.5
>           COLOR 140 140 138
>        ANTIALIAS true
>     END
>   END #class
> END # Layer
> Here's the image output info:
> OUTPUTFORMAT
>   NAME png24
>   DRIVER "GD/PNG"
>   MIMETYPE "image/png"
>   IMAGEMODE RGB
>   EXTENSION "png"
> END
> Any suggestions?
> Thanks,
> Jennifer
> Jennifer Strahan (Shanks)
> GreenInfo Network - 1996-2006: A Decade of Mapping the Public Interest
> 116 New Montgomery  Street   Suite 738  San Francisco CA  94105
> PH: (415)979-0343 x306    Fax:  415-979-0371     Web:  www.greeninfo.org
Andreas Albarello
Analysis & SW Development
Territorium Online srl/GmbH
Via Buozzi/Buozzistraße 12 - I 39100 Bolzano/Bozen
email: andreas.albarello at territoriumonline.com
web:   www.territoriumonline.com
