PHP setup using tomcat
Delfos, Jacob Jacob.Delfos at MAUNSELL.COM
Wed Sep 20 23:20:33 EDT 2006
Mark,
I don't believe there is a very simple solution to getting php to run on
tomcat. I had to do it myself a while ago, and it seems the general
agreement out there is that for best performance, you should run PHP
using Apache webserver (on port 80), and then use a proxy/reverse proxy
for running Tomcat on a different port, proxied through the normal
Apache webserver. You can then run Tomcat on a different port, while
running Apache on the normal port. This works for me, but I'm no expert
on this.
Is there any reason why you are using Tomcat? You mentioned it's for
Ka-Map, but Ka-Map is php-based.
Regards,
Jacob
> -----Original Message-----
> From: UMN MapServer Users List
> [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Mark Howard
> Sent: 21 September 2006 11:14
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: [UMN_MAPSERVER-USERS] PHP setup using tomcat
> I'm setting up a Tomcat server to use for ka-maps. I've got mapserv
> working correctly in the C:\tomcat\webapps\ROOT\WEB-INF\cgi folder
> (as http://my_server/cgi-bin/mapserv.exe).
> So this works fine:
> http://my_server/cgi-bin/mapserv.exe?REQUEST=GetMap&VERSION=1.
> 1.1&MAP=C:
> \tomcat\webapps\ka-map\Akidemo\AkiDemo1.map&SRS=EPSG:4326&bbox
> =-180,-90,
> 180,90&width=200&height=200&layers=countries&format=image/PNG
> I've got PHP installed and configured --  php.exe and php.ini are in
> C:\WINDOWS\system32 and the php.ini extension_dir =
> /ms4w/Apache/php/ext/
> This works on the command line - for example:
> makes a perfectly good png.
> Where quickmap.php has
> // define variables
> define( "MAPFILE", "C:/tomcat/webapps/ka-map/AkiDemo1.map" );
> define( "MODULE", "php_mapscript_48.dll" );
> However If I access the same php file in a web context, I just get the
> php file streamed back. Obviously php is not running. I tried putting
> php and all the dll's in the cgi folder (probably stupid - eh?).
> Do I need to download and install a php class library (jar)
> to run as a
> servlet - as in these instructions? --
> http://blog.taragana.com/index.php/archive/running-php-5x-on-w
> indows-usi
> ng-tomcat-4x-or-5x/
> OR is there something simple I'm missing in the system configuration
> (web.xml....)????
> TIA for any assistance!!!!!
> Mark
> JMEWS II/Medical Situational Awareness (MSA)
> Akimeka, LLC
> 1305 North Holopono Street, Suite # 3
> Kihei, HI 96753
> Office (808) 442-7137
> Fax    (808) 442-7140
> Cell   (303) 829-1255
> mhoward at akimeka.com
