adding label to point layer in PHPMapscript
Murat BEYHAN
beyhan at DEPREM.GOV.TR
Tue Sep 26 10:26:57 EDT 2006
Dear Pietro;
Thank you for your suggestion.
But still the label doesn't appearing
I have change some point in yor result you sent me..
Please check it.
I really try to write label with point by using PHP but I couldn't find any
result on the list archive or on the web.
Thank you very much for your interest....
the code which I changed a little are here.....
$map_path="/var/www/html/zone/";
$map = ms_newMapObj($map_path."zone.map");
$map->setExtent($nMinX, $nMinY, $nMaxX, $nMaxY);
// create a temp layer to hold our points
$point_layer = ms_newLayerObj($map);
$point_layer->set("name", "markers");
$point_layer->set("type", MS_LAYER_POINT);
$point_layer->set("status", MS_DEFAULT);
$point_layer->setProjection("proj=latlong",MS_TRUE);
// create a class and style for this layer
$point_class = ms_newClassObj($point_layer);
$point_style = ms_newStyleObj($point_class);
$koyadi="deneme";
$point_layer->set("labelitem","$koyadi");
$point_symbol = $map->getSymbolByName("cpoint");
$point_style->set("symbol", $point_symbol);
$point_style->set("size", 12);
$point_style->color->setRGB(255,0,255);
$point_style->outlinecolor->setRGB(255,255,0);
/* setting a label on the class */
// $label = $class->label; /***** here also I have changed... as follows */
$label = $point_class->label;
$label->set("position", MS_CC);
$label->set("font","arial");
$label->set("type",MS_BITMAP);/* I HAVE CHANGE THIS LINE BECAUSE
freetype format doesn't supporting my mapserver. I also try to find a solution
for that.*/
$label->set("size","large"); /* also hereeeeeeee*/
$longitude=$lon;// comes from select queries from mysql as a result
$latitude=$lat;// comes from select queries from mysql as a result
/* now the method is a bit more complicated as precedent */
/* create and locate a point object */
$point = ms_newPointObj(); /* is this will be $point_layer for my code???*/
$point->setXY($longitude, $latitude);
/* create a line object and add the point */
$line = ms_newLineObj();
$line->add($point);
/* create a shape object and add the mono-point line */
$shape = ms_newShapeObj(MS_SHAPE_POINT);
$shape->add($line);
/* set the "text" property of the shape */
$shape->set("text","show must go on");
/* add this shape to the layer */
$point_layer->addFeature($shape); /* also hereeee*/
/* now you can create the image of the map and save it */
// $image = $oMap->draw();
$image = $map->draw();
$map_url=$image->saveWebImage();
/* you don't need to invoke the */
// $point->draw($map, $layer, $image, 0, "");
// draw our image without the points
$ref = $map->drawreferencemap();
$legend=$map->drawLegend();
On Tue, 26 Sep 2006 15:33:08 +0200, Pietro Giannini wrote
> hi Murat,
> i tried so, and works:
> $label->set("type",MS_TRUEYPE);
> $label->set("size",12);
> $line->add($point);
> $shape->add($line);
> $layer->addFeature($shape);
> best regards
> Pietro
> ___________________________
> Pietro Giannini
> Bytewise srl - Area GIS
> 41°50'38.58"N 12°29'13.39"E
> On Mar, 26 Settembre 2006 11:48, Murat BEYHAN disse:
> > Dear Jacob,
> > The following php codes bring one of the record from mysql I mean only one
> > row.
> > That row consist of the cityname (iladi), districtname (ilceadi) and
> > village name (koyadi).
> > $query = "SELECT * FROM $db_tb WHERE iladi LIKE '$iladi' AND
> > ilceadi LIKE '$ilceadi' AND koyadi LIKE '$koyadi'";
> > $result = mysql_query($query) or die("Query failed : " . mysql_error());
> > $num = mysql_numrows($result);
> > $i=0;
> > while ($i < $num) {
> > $koyadi = mysql_result($result,$i,"koyadi");
> > $ilceadi = mysql_result($result,$i,"ilceadi");
> > $iladi = mysql_result($result,$i,"iladi");
> > $zone = mysql_result($result,$i,"zone");
> > $lon = mysql_result($result,$i,"lon");
> > $lat = mysql_result($result,$i,"lat");
> > ++$i;
> >> Have you tested whether any part of this code works? Which part is
> >> giving you trouble? Does your PHP log say anything?
> > By using this query result I'm drawing point of the village on the map.
> > The part of this issue does work succesfully. I mean drawing of the point
> > was achieved already by the support of the list user.
> > The second step Which I intend to write the name of village near to point.
> > So I was changed the name of koyadi into villagename in order to
> > understand for people in my message. sorry.
> > Now I have tried to ad your suggestion into the php code but still the
> > name of village doesnt appearing on the map..
> > I hope I could explained What I'm trying to do.
> > Thanks.
> > Murat
> > The new codes are here after your suggestion. But I2m not sure exacly
> > where I have to put your suggestion on the code.
> > $label->set("font","sans");
> > $label->set("size",MS_MEDIUM);
> > $label->color->setRGB(22,8,3);
> > $label->backgroundcolor->setRGB(0,0,0);
> > $label->set(minsize,4);
> > $label->set(maxsize,100000);
> > // initialize our point and add it to the map
> > echo $longitude, ' ', $lat;
> > $point->draw($map, $point_layer, $image, 0, "");
> > $ref_url = $ref->saveWebImage();
> > $legend_url=$legend->saveWebImage();
> > On Tue, 26 Sep 2006 16:04:33 +0800, Delfos, Jacob wrote
> >> Murat,
> >> Are you sure you want all your villages to have the same label
> >> ($villagename)?
> >> I think you may want to define a labelitem:
> >> $point_layer->set("labelitem","villagename"); // "villagename" is the
> >> name of the attribute of the layer
> >> Also, you quoted "$koyadi", which is probably not correct. Or remove the
> >> regards,
> >> Jacob
> > This message has been scanned for viruses and
> > dangerous content by MailScanner, and is
> > believed to be clean.
