replace MAP extension with ASPX or ASP
william paul
williampaul28 at YAHOO.COM
Fri Sep 29 08:37:00 EDT 2006
Hello:
Is it possible to replace the map extension with aspx or asp? I have seen an example (http://www2.tetonwyo.org/mapserver/) where the map file is called map.asp. I tried to create an aspx file like:
<%Response.Write ("Map")%>.....and all the line for a map file, but when I try to replace the http://localhost/scripts/mapserv.exe?map=map.map.... with http://localhost/scripts/mapserv.exe?map=map.aspx I get an regualar expression error
I want to be use ASPX or ASP to create the lines code from a basic map file
Does anyone can give me an example?
Thank you
William
Get your own web address for just $1.99/1st yr. We'll help. Yahoo! Small Business.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060929/73f79ad4/attachment.html
