replace MAP extension with ASPX or ASP
Pascoe,Tim [Burlington] Tim.Pascoe at EC.GC.CA
Fri Sep 29 08:56:44 EDT 2006
William,
            I'm not sure, but think I know what is happening on the example you supplied, as I do the same thing. In order to suppress the path information normally visible in the browser address bar, the developer has implemented a simple ASP script which passes the mapserver arguments through. Below is the script I use, which I got from either this list, or one of the Mapserver support sites (can't remember, but I'm not taking credit....).
Hope this helps explain a bit, but I don't think it is actually what you want to do; I think you are looking to build the map file on the fly, correct?
    Server.ScriptTimeout = 360
    Select Case Request.ServerVariables("REQUEST_METHOD")
      Case "GET"  strRequest = Request.QueryString
      Case "POST" strRequest = Request.Form
    End Select
    strURL = "http://web.address/mapserv.exe?map=C:\path\to\mapfile\map.map&" & strRequest
    Dim objHTTP
    Set objHTTP = Server.CreateObject("MSXML2.ServerXMLHTTP")
    objHTTP.open "GET", strURL, false
    objHTTP.send ""
    Response.ContentType = objHTTP.getResponseHeader("content-type")
    Response.BinaryWrite objHTTP.responseBody
    Set objHTTP = Nothing
Timothy Pascoe
Environmental Systems Scientist
Environment Canada / Environnement Canada
Canada Centre for Inland Waters / Centre Canadien des Eaux Intérieures
867 Lakeshore Road / 867, chemin Lakeshore
Burlington, Ontario / Burlington (Ontario)
L7R 4A6
Tel/Tél: (905) 336-6239
Fax/Téléc: (905) 336-4699
E-mail/C. élec: tim.pascoe at ec.gc.ca <mailto:tim.pascoe at ec.gc.ca>
Government of Canada/Gouvernement du Canada
This e-mail represents the opinions and views solely held by its author and in no manner may be considered as representing those of his/her employer.
  _____
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of william paul
Sent: September 29, 2006 8:37 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] replace MAP extension with ASPX or ASP
Hello:
Is it possible to replace the map extension with aspx or asp? I have seen an example (http://www2.tetonwyo.org/mapserver/) where the map file is called map.asp. I tried to create an aspx file like:
<%Response.Write ("Map")%>.....and all the line for a map file, but when I try to replace the http://localhost/scripts/mapserv.exe?map=map.map.... with http://localhost/scripts/mapserv.exe?map=map.aspx I get an regualar expression error
I want to be use ASPX or ASP to create the lines code from a basic map file
Does anyone can give me an example?
Thank you
William
  _____
Get your own web address for just $1.99/1st yr. We'll help. Yahoo! Small Business <http://us.rd.yahoo.com/evt=41244/*http:/smallbusiness.yahoo.com/> .
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060929/c44634c8/attachment.html
