same effect as CGI mode=itemquerymap but with PHP/mapscript
Rodrigo Martín LÓPEZ GREGORIO
rodrigomlg at GMAIL.COM
Fri Aug 3 12:50:24 EDT 2007
Hi List.
Normally I use mapserver as CGI, but now I need to move to PHP/mapscript. In
my actual applet I use the CGI mode=itemquerymap to show the selected
polygon on a layer with different color. So I pass the next values on the
CGI call:
mode=itemquerymap&qlayer=mylayer&qstring=someattribute='avalue'
This works greats through CGI. Now I want to get the same effect using PHP
Mapscript but I'm a little confused how to get it working. I know how to get
the string parameters in php, even split the qstring parameter using explode
but what I don't know is what must I do to get PHP Mapscript use the
QUERYMAP format (defined in my base mapfile) to show the selected polygon.
Can anyone give me a hint?
Thanks.
Rodrigo.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20070803/5616e690/attachment.html
