use of shp2tile and ogrtindex
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Thu Aug 9 09:05:29 EDT 2007
Antonio wrote:
> Hi,
> I am using shp2tile to split my huge shapefile , after that I use
> ogrtindex to generate the tileindex.
> So in my map file in the layer definition I set the keyword TILEINDEX at
> this new tilendex shape just generated.
> This work fine for the layer with TYPE POLYGON but doesn't work with
> RASTER layer.
> Some one could tell me why?
> thanks
> Antonio
I hope you are not trying to use shp2tile to tile rasters! :-0
As the name implies Shape 2 tiles is not the same as raster 2 tiles.
gdal has tools that will let you do the equivalent to rasters. Also you
need to use gdaltindex to build you tileindex for rasters.
-Steve
