qix files
Flavio Hendry flavio at TYDAC.CH
Thu Aug 9 09:46:16 EDT 2007
Hi Marcos
do NOT use a .shp extension in your mapfile (DATA section). this will
solve it:
LAYER
  NAME "Parcels"
  STATUS ON
  DATA "surveying/parcels"
  TYPE POLYGON
  CLASS
      COLOR 255 255 204
      OUTLINECOLOR 0 0 0
  END
END
Mit freundlichem Gruss / Best Regards
Flavio Hendry
TYDAC Web-Site:  http://www.tydac.ch
TYDAC MapServer: http://www.mapserver.ch
############      Mit freundlichen Gruessen / Kind Regards
############             mailto:flavio at tydac.ch
############         TYDAC AG - http://www.tydac.ch
####    ####        Geographic Information Solutions
####    ####         Luternauweg 12 -- CH-3006 Bern
############   Tel +41 (0)31 368 0180 - Fax +41 (0)31 368 1860
-----Original Message-----
From: Marcos Sánchez Provencio <marcos at BURKE.ATH.CX>
To: MAPSERVER-USERS at LISTS.UMN.EDU
Date: Thu, 9 Aug 2007 14:37:35 +0200
Subject: [UMN_MAPSERVER-USERS] qix files
> Now that I've seen how kind you are...
> I get this warning I cannot ignore, since it comes up as an error:
> IOError at /simif/wms/mapserv/
> msSearchDiskTree(): Unable to access file. Unable to open spatial
> index
> for
> /home/simif/src/simif/mapas/vardatos/PENINSULA_fc200708090001.4.shp.q
> ix. In most cases you can safely ignore this message, otherwise check
> file names and permissions.
> Can I ignore the message (with some kind of ignore warnings flag)?
> Can I
> force it not to use qix file, no matter how slow it works?
> Alternatively, I have a shx file (some kind of index too, I guess),
> can
> I make it use that instead?
> Also, if I generate the qix file, mapbuilder either does not find
> PENINSULA_fc200708090001.4.shp (if i do not include .shp) or
> PENINSULA_fc200708090001.4.qix (if i do include it). Funny :-P
> Anything better than generating qix files and renaming them to
> .shp.qix?
