qix files
Gaston Izaguirre
gizagui at FI.UBA.AR
Thu Aug 9 11:03:09 EDT 2007
Marcos,
Check your mapfile for the definition of your vector layer:
Shapefiles are native to MapServer, and therefore do not require the .shp
extension in the DATA path of the LAYER.
In fact, in order for MapServer to use the .qix extension you MUST NOT
specify the extension, for example:
LAYER
DATA us_states #MapServer will search for us_states.qix and will use it
END
LAYER
DATA us_states.shp #MapServer will search for us_states.shp.qix and
won't find it
END
Extracted from
http://mapserver.gis.umn.edu/docs/reference/utilityreference/shptree
Saludos,
Gaston.
----- Original Message -----
To: <MAPSERVER-USERS at LISTS.UMN.EDU>
Sent: Thursday, August 09, 2007 9:37 AM
Subject: [UMN_MAPSERVER-USERS] qix files
> Now that I've seen how kind you are...
> I get this warning I cannot ignore, since it comes up as an error:
> IOError at /simif/wms/mapserv/
> msSearchDiskTree(): Unable to access file. Unable to open spatial index
> for
> /home/simif/src/simif/mapas/vardatos/PENINSULA_fc200708090001.4.shp.qix.
> In most cases you can safely ignore this message, otherwise check file
> names and permissions.
> Can I ignore the message (with some kind of ignore warnings flag)? Can I
> force it not to use qix file, no matter how slow it works?
> Alternatively, I have a shx file (some kind of index too, I guess), can
> I make it use that instead?
> Also, if I generate the qix file, mapbuilder either does not find
> PENINSULA_fc200708090001.4.shp (if i do not include .shp) or
> PENINSULA_fc200708090001.4.qix (if i do include it). Funny :-P
> Anything better than generating qix files and renaming them to .shp.qix?
