Mapserv can't find libpq.so
Bill Thoen bthoen at GISNET.COM
Sat Aug 11 16:37:00 EDT 2007
Never mind... Yes, you DO have to add /usr/local/pgsql/lib to
/etc/ld.so.conf and run /sbin/ldconfig so that mapserv can find the
library. I've aded this to my notes so I won't have *this* problem again.
On Sat, Aug 11, 2007 at 02:24:00PM -0600, Bill Thoen wrote:
> I just built a 4.10.2 version of MapServer from source and included support
> for GEOS, GDAL, POstgis and Proj4, but now when mapserv runs it dies saying
> it can't find libpq.so. However, the library is sitting in
> /usr/local/pqsql/lib. Do I need to add this path to ld.so.conf, or should I
> look elsewhere to fix this?
> The last time I built a copy of MapServer, I didn't have this problem, and
> as I took notes then, I have just been following these. Obviously I left
> something important out, but would appreciate it if someone could tell me
> what's wrong.
> Thanks,
> - Bill Thoen
