Strange MS beta3 behaviour..
Sture Dingsøyr candalt at ONLINE.NO
Thu Aug 16 08:48:55 EDT 2007
Hi again..
Tried to set STATUS ON directly in the mapfile on a POSTGIS layer and the same strange behaviour still occur.
One remark...the page does not "hang" forever...it just uses many more seconds (4-5) before it is finished rendered, than in the previous version of MS4W (2.2.3).
I do not hav DEBUG TRUE enabled in my mapfile.
Sture
-----Opprinnelig melding-----
Fra: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] På vegne av Daniel Morissette
Sendt: 16. august 2007 14:06
Til: MAPSERVER-USERS at LISTS.UMN.EDU
Emne: Re: [UMN_MAPSERVER-USERS] Strange MS beta3 behaviour..
Sture Dingsøyr wrote:
> Hello...
> Been testing the new beta release of MS4W (beta3), and i have noticed a strange behaviour.
> I use a small PHP mapscript to generate a picture. But when I use the mapscriptfunction "set("status", 1)" on a POSTGIS, WMS or WFS layer...the web browser "hangs" for many seconds before the PHP page is finished rendering.
> This behaviour dos not occur when "set("status", 1)" is used on a ESRI SHAPE or a RASTER layer.
This is definitely very strange. If you set "STATUS ON" directly in the mapfile then does it hang as well? If yes then that at least tells us that the problem has nothing to do with the set("status", 1) call.
Oh wait... those symptoms are similar to what we had in ticket #458
(http://trac.osgeo.org/mapserver/ticket/458) ... do you use DEBUG TRUE in your mapfile with MS_ERRORFILE "stderr"? If yes then perhaps try disabling it and see if that makes a difference.
Daniel
Daniel Morissette
http://www.mapgears.com/
