Error on Itemnquery with PostGIS-layer
Umberto Nicoletti
umberto.nicoletti at GMAIL.COM
Tue Aug 21 08:01:23 EDT 2007
You probably have to add the columns in the CONNECTION STATEMENT.
Umberto
On 8/21/07, HarryS <mapcollect at gmx.net> wrote:
> this is the layer configuration:
> LAYER
> NAME "City-Database"
> GROUP "Databases"
> STATUS default
> DATA "the_geom from name"
> CONNECTION "user=postgres dbname=geonamesallppl host=localhost
> port=5432"
> CONNECTIONTYPE postgis
> TYPE QUERY
> CLASS
> TEMPLATE "template-city.html"
> END
> METADATA
> "queryable" "true"
> "searchfield" "name"
> "fields"
> "name:Name,population:Pop,country:Country,province:Province,CODE:Code"
> END
> END
> Mapserver can render maps using this layer and also searching via
> KaMap-Frontend works on this layer, only itemnquery via cgi gives me the
> above quoted error. I tried using different cases with column names (NAME,
> Name, name) but always got same error: ...ERROR: Column »london« does not
> exist...
> This I don't understand because »london« is the querystring and not the
> column-name.
> Thanks,
> Harry
> Umberto Nicoletti wrote:
> > Please post the layer configuration for postgis AND check the case of
> > the column name.
> > Postgres handles column names with case sensitivity if, at table
> > creation, the column name was in quotes. In that case you have the
> > specify the column name with exactly the same case and in quotes; this
> > is most likely the reason.
> > HTH,
> > Umberto
> >> doing this query:
> >> http://myServer.com/cgi-bin/mapserv?&map=/home/harry/Mapfiles/MyMap.map&mode=itemnquery&qlayer=City-Database&qitem=NAME&qstring='London'
> >> produces this Error:
> >> prepare_database(): Query error. Error executing POSTGIS DECLARE (the
> >> actual
> >> query) statement: 'DECLARE mycursor BINARY CURSOR FOR SELECT
> >> from name WHERE (London) and (the_geom && setSRID( 'BOX3D(-180 -90,180
> >> 90)'::BOX3D,find_srid('','name','the_geom') ))'
> >> Postgresql reports the error as 'FEHLER: Spalte »london« existiert nicht
> >> (Translation: ERROR: Column »london« does not exist)
> >> More Help:
> >> Error with POSTGIS data variable. You specified '<check your .map file>'.
> >> Standard ways of specifiying are :
> >> (1) 'geometry_column from geometry_table'
> >> (2) 'geometry_column from (<sub query>) as foo using unique <column name>
> >> using SRID=<srid#>'
> >> Make sure you put in the 'using unique <column name>' and 'using SRID=#'
> >> clauses in.
> >> For more help, please see http://postgis.refractions.net/documentation/
> >> Mappostgis.c - version of Jan 23/2004.
> >> If I do the same query on the same layer but using a shapefile instead of
> >> PostGIS for identical data the query works fine without any errors. Can
> >> someone point me to my mistake, please ?
> >> Harry Schmidt
> >> View this message in context:
> >> http://www.nabble.com/Error-on-Itemnquery-with-PostGIS-layer-tf4303941.html#a12250916
> >> Sent from the Mapserver - User mailing list archive at Nabble.com.
> View this message in context: http://www.nabble.com/Error-on-Itemnquery-with-PostGIS-layer-tf4303941.html#a12252666
