Error on Itemnquery with PostGIS-layer
Umberto Nicoletti umberto.nicoletti at GMAIL.COM
Tue Aug 21 08:01:54 EDT 2007
Sorry, I meant the DATA statement.
Umberto
On 8/21/07, Umberto Nicoletti <umberto.nicoletti at gmail.com> wrote:
> You probably have to add the columns in the CONNECTION STATEMENT.
> Umberto
> On 8/21/07, HarryS <mapcollect at gmx.net> wrote:
> > this is the layer configuration:
> > LAYER
> >     NAME "City-Database"
> >     GROUP "Databases"
> >     STATUS default
> >     DATA "the_geom from name"
> >     CONNECTION "user=postgres dbname=geonamesallppl host=localhost
> > port=5432"
> >     CONNECTIONTYPE postgis
> >     TYPE QUERY
> >     CLASS
> >       TEMPLATE "template-city.html"
> >     END
> >   METADATA
> >    "queryable" "true"
> >    "searchfield" "name"
> >    "fields"
> > "name:Name,population:Pop,country:Country,province:Province,CODE:Code"
> >   END
> >   END
> > Mapserver can render maps using this layer and also searching via
> > KaMap-Frontend works on this layer, only itemnquery via cgi gives me the
> > above quoted error. I tried using different cases with column names (NAME,
> > Name, name) but always got same error: ...ERROR: Column »london« does not
> > exist...
> > This I don't understand because »london« is the querystring and not the
> > column-name.
> > Thanks,
> > Harry
> > Umberto Nicoletti wrote:
> > > Please post the layer configuration for postgis AND check the case of
> > > the column name.
> > > Postgres handles column names with case sensitivity if, at table
> > > creation, the column name was in quotes. In that case you have the
> > > specify the column name with exactly the same case and in quotes; this
> > > is most likely the reason.
> > > HTH,
> > > Umberto
> > >> doing this query:
> > >> http://myServer.com/cgi-bin/mapserv?&map=/home/harry/Mapfiles/MyMap.map&mode=itemnquery&qlayer=City-Database&qitem=NAME&qstring='London'
> > >> produces this Error:
> > >> prepare_database(): Query error. Error executing POSTGIS DECLARE (the
> > >> actual
> > >> query) statement: 'DECLARE mycursor BINARY CURSOR FOR SELECT
> > >> from name WHERE (London) and (the_geom && setSRID( 'BOX3D(-180 -90,180
> > >> 90)'::BOX3D,find_srid('','name','the_geom') ))'
> > >> Postgresql reports the error as 'FEHLER: Spalte »london« existiert nicht
> > >> (Translation: ERROR: Column »london« does not exist)
> > >> More Help:
> > >> Error with POSTGIS data variable. You specified '<check your .map file>'.
> > >> Standard ways of specifiying are :
> > >> (1) 'geometry_column from geometry_table'
> > >> (2) 'geometry_column from (<sub query>) as foo using unique <column name>
> > >> using SRID=<srid#>'
> > >> Make sure you put in the 'using unique <column name>' and 'using SRID=#'
> > >> clauses in.
> > >> For more help, please see http://postgis.refractions.net/documentation/
> > >> Mappostgis.c - version of Jan 23/2004.
> > >> If I do the same query on the same layer but using a shapefile instead of
> > >> PostGIS for identical data the query works fine without any errors. Can
> > >> someone point me to my mistake, please ?
> > >> Harry Schmidt
> > >> View this message in context:
> > >> http://www.nabble.com/Error-on-Itemnquery-with-PostGIS-layer-tf4303941.html#a12250916
> > >> Sent from the Mapserver - User mailing list archive at Nabble.com.
> > View this message in context: http://www.nabble.com/Error-on-Itemnquery-with-PostGIS-layer-tf4303941.html#a12252666
