Rendering glitches with MS 5.1-devel
Gregor Mosheh
gregor at HOSTGIS.COM
Thu Dec 6 03:34:18 EST 2007
thomas bonfort wrote:
> quantization is poorly supported for rgba images, you'll have to use
> 24bit pngs in that case.
I'm sorry for not including the relevant section of mapfile.
OUTPUTFORMAT
NAME png
DRIVER "AGG/PNG"
MIMETYPE "image/png"
IMAGEMODE RGB
EXTENSION png
TRANSPARENT on
FORMATOPTION "INTERLACE=no"
END
To reiterate, the map is: http://69.59.158.8/
The highways layer's shields, and the base layer's bleed-over from
Canada into the USA (turn off satellite), are the most obvious bugs.
Gregor Mosheh / Greg Allensworth
System Administrator, HostGIS cartographic development & hosting services
http://www.HostGIS.com/
"Remember that no one cares if you can back up,
only if you can restore." - AMANDA
