style - pattern - Mapserver 5
rich.fromm
nospam420 at YAHOO.COM
Thu Dec 13 20:25:36 EST 2007
NETGIS Schroeter wrote:
> Hallo list,
> till Mapserver 4.10 the style parameter in a symbol definition has been
> used
> to store dash patterns like the example below (railway). Now in version
> 5.0
> it is recommend change STYLE to PATTERN, but regardless of which parameter
> there is no effect. Neither STYLE nor PATTERN produces a distance.
> SYMBOL
> NAME 'punkt'
> TYPE ELLIPSE
> POINTS
> 1 1
> END
> FILLED TRUE
> END
> SYMBOL
> NAME 'rechteck-bahn'
> TYPE VECTOR
> POINTS
> 0 0
> 0 0.6
> 1 0.6
> 1 0
> 0 0
> END
> FILLED TRUE
> STYLE
> 8 12 8 12
> END
> END
i don't know about combining STYLE/PATTTERN with TYPE VECTOR. in my only
case, i defined exactly what i wanted repeated in the vector POINTS, and
that pattern is repeated, with no gaps.
in the case of a simple on/off pattern (which is i assume you're trying to
do with the TYPE ELLIPSE), i think the gist is that you no longer need to
use ellipses to draw lines. something like the following ought to suffice:
SYMBOL
NAME 'dashed1'
TYPE SIMPLE
PATTERN
1 1
END
END
- rich
View this message in context: http://www.nabble.com/style---pattern----Mapserver-5-tp14312872p14328403.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
