Mapscript 4.10.0 and 4.10.2 gives segfault with Postgres 8.2 [SEC=UNCLASSIFIED]
Andreas Albarello andreas.albarello at TERRITORIUMONLINE.COM
Wed Jul 4 04:41:31 EDT 2007
Roppola, Antti - BRS wrote:
> Hi all,
> We're in the process of upgrading from 4.8.1 to 4.10.2 and we are seeing
> segfaults
> when using PostGIS layers. I've had a look through the bug tracker and
> source, the main
> difference between msPOSTGISLayerRetrievePK() between 4.8.1 and 4.10.2
> appears
> to be the following (mappostgis.c revisions 1.66 to 1.77):
Antti,
yes, this looks indeed like a bug in msPOSTGISLayerRetrievePK to me.
I've had a look at the code and I could spot line 1770 of mappostgis.c
(Mapserver 4.10.1, line number might vary slightly in other versions)
which doesn't really look very effective:
       length = (int)pos_sep + strlen(pos_sep);
Casting a pointer into an int doesn't seem to make any sense here. I'd
suggest you change that line to
       length = strlen(pos_sep);
recompile and try again.
Best regards,
Andreas Albarello
Analysis & SW Development
Territorium Online srl/GmbH
Via Buozzi/Buozzistraße 12 - I 39100 Bolzano/Bozen
email: andreas.albarello at territoriumonline.com
web:   www.territoriumonline.com
