Mapscript, SVG and Annotations
Martin Weinelt
mweinelt at PLANIGLOBE.COM
Wed Jul 11 04:46:25 EDT 2007
Thanks a lot,
your tips at least kept trying. What I did was translate your example
to Perl mapscript. Some PHP methods are not available or a bit
different in the SWIG versions. That looks like this:
my $oShp = new mapscript::shapeObj($mapscript::MS_SHAPE_POINT);
my $oLine = new mapscript::lineObj;
my $oPt = new mapscript::pointObj;
$oPt->setXY(-11, 22); # DD
$oLine->add($oPt);
$oShp->add($oLine);
$oShp->{text} = 'Hello World';
my $numlayers = $map->{numlayers};
my $oLayer;
for (my $h=0; $h<$numlayers; $h++) {
$oLayer = $map->getLayer($h);
$oLayer->{status} = $mapscript::MS_OFF;
$oLayer = $map->getLayerByName('popplace');
$oLayer->{status} = $mapscript::MS_ON;
$oLayer->addFeature($oShp);
# here the loop below is going to be inserted
my $SVGimg = $map->draw();
my $svg_file = '/path/to/willi.svg';
$SVGimg->save($svg_file);
The result is exactly like yours: including the label. Ok.
But now I add the following:
for (my $foo=0; $foo < 3; $foo++) {
$oPt->setXY($foo,$foo);
$oLine->add($oPt);
$oShp->add($oLine);
$oShp->{text} = 'Hello World ' . "$foo";
$oShp=$oLine=$oPt=undef; # don't know if this is needed
this is the result:
<svg version="1.1" width="530" height="350"
xmlns="http://www.w3.org/2000/svg"
xmlns:xlink="http://www.w3.org/1999/xlink">
<!-- START LAYER popplace -->
<ellipse cx="249" cy="143" rx="3" ry="3" fill="#0000ff" />
<ellipse cx="265" cy="175" rx="3" ry="3" fill="#0000ff" />
<ellipse cx="266" cy="174" rx="3" ry="3" fill="#0000ff" />
<ellipse cx="268" cy="172" rx="3" ry="3" fill="#0000ff" />
<text x="249" y="142" font-family="Arial" font-size="12pt"
fill="#ff0000" stroke="#ffffff" stroke-width="0.5"
transform="rotate(-10.000000 249 142)">Hello World</text>
</svg>
What you see is that the labels from the loop are missing while the
label from the first addFeature is there. Weird.
Going through the MAP-file reference I find the 'FORCE' property for
labels. Setting 'FORCE' to 'true' did the trick. All labels,
including those from the loop, do now appear in the SVG. I do not
know if this is exactly what I want, but at least I got my labels.
Cheers,
Martin
On Dienstag 10 Juli 2007, Yewondwossen Assefa wrote:
> Hi there,
> I did a quick test using php mapscript and an svg output. The
> poplace layer in the map file is a point layer and has a class with
> a label object (note that there is no labelitem set)
> LAYER
> NAME popplace
> TYPE POINT
> STATUS ON
> CLASS
> style
> SYMBOL 'circle'
> SIZE 6
> COLOR 0 0 255
> END
> LABEL
> COLOR 255 0 0
> # FONT fritqat-italic
> FONT Arial
> TYPE truetype
> SIZE 12
> ANGLE 10
> POSITION AUTO
> PARTIALS FALSE
> OUTLINECOLOR 255 255 255
> END
> script looks something like this
> $oMap = ms_newmapobj("c:/msapps/gmap-ms40/htdocs/gmap75.map");
> $oShp = ms_newShapeObj(MS_SHAPE_POINT);
> $oLine = ms_newLineObj();
> $oLine->addXY(-2299954.0642738,-612631);
> $oShp->add( $oLine );
> $oShp->set("text", "mytext");
> $numlayers = $oMap->numlayers;
> for ($i=0; $i<$numlayers; $i++)
> $oLayer = $oMap->getlayer($i);
> $oLayer->set("status", MS_OFF);
> $oLayer = $oMap->getlayerbyname('popplace');
> $oLayer->set("status", MS_ON);
> $oLayer->addfeature($oShp);
> $img = $oMap->draw();
> $url = $img->saveWebImage();
> header("Content-type: image/svg+xml");
> $url = $img->saveImage("");
> It produces an svg point with the label my text :
> <ellipse cx="39" cy="586" rx="3" ry="3" fill="#0000ff" />
> <text x="38" y="581" font-family="Arial" font-size="12pt"
> transform="rotate(-10.000000 38 581)">mytext</text>
> </svg>
> Not sure what the issue would be in your case, the only time I
> did not have the text produced was when I set the labelitem object.
> Could that be the case ?
> Later
> kk+w - digitale kartografie GmbH wrote:
> > Hi,
> > I am using addFeature to dynamically add site locations with a
> > label to a map. It's Perl mapscript.
> > @sites is an array of hash references, $sitesLyr is from the map
> > file:
> > foreach my $site (@sites) {
> > my $site_pt = $$site{'site_loc'};
> > $site_pt =~s/.*\((.*)\)*./$1/; # extract the points x and
> > y my $line = new mapscript::lineObj();
> > my $siteShp = new
> > my $point = new mapscript::pointObj();
> > my($x,$y) = split(/ /, $site_pt);
> > $point->setXY($x,$y);
> > $line->add($point);
> > $siteShp->add($line);
> > $siteShp->{text} = $$site{'site_name'};
> > $siteShp->setBounds();
> > $sitesLyr->addFeature($siteShp);
> > my $img = $map->draw();
> > This works perfectly for the usual PNG output map. Using the same
> > routine for a SVG 'image' results in the symbols/markers getting
> > plotted, but the labels are missing. If I switch to a static
> > shapefile for this layer, the labels do appear in the SVG.
> > Is there anything special with SVG output and the 'addFeature'
> > method for layers that I am missing?
> > Thanks,
> > Martin
