Rename: Getting DBF data for symbology
Fawcett, David David.Fawcett at STATE.MN.US
Mon Oct 15 09:39:17 EDT 2007
I believe that transparency/opacity currently is only available at the
layer level, not the class level as Hayden appears to want.
If you really need the transparency option, you could break out your
classes into separate layers.  This would allow you to use transparency,
but would of course multiply the number of layers and may give you a
very small performance hit (which may likely be negligible).
David.
	-----Original Message-----
[mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Mevima Winn
	Sent: Friday, October 12, 2007 12:23 PM
	To: MAPSERVER-USERS at LISTS.UMN.EDU
	Subject: Re: [UMN_MAPSERVER-USERS] Rename: Getting DBF data for
symbology
	There are a couple of ways.
	First is to set a transparency level, if the polygons have to be
solid.  Underlying polygon doesn't have to have any, while the top
polygon can have any transparency level you want - probably somewhere
between 40 and 60% if you want both to be approximately equally visible.
	Or you can simply set an OUTLINECOLOR and no COLOR, which means
you will get an outline and no fill, which will show any underlying
polygons as long as they don't directly overlap the same lines.  Any
overlapping lines can be identified by making the outline line thicker
and a different color, so whoever is viewing the map can see that there
are multiple polygons there.
	Regards,
	-Mevima
[mailto:MAPSERVER-USERS at LISTS.UMN.EDU]On Behalf Of Hayden Fisher
		Sent: Thursday, October 11, 2007 10:47 PM
		Subject: [UMN_MAPSERVER-USERS] Rename: Getting DBF data
for symbology
		Also polygons on top of polygons, is there a way to make
it so you can see both?
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20071015/698639e4/attachment.html
