mapscript point layer zooming
Tamas Szekeres szekerest at GMAIL.COM
Thu Oct 18 16:56:37 EDT 2007
You might want to test with the drawmap C# sample (can be found in the
ms4w package as well) to see whether the application can draw the
layer with the same extent. (set the extent of the map in the mapfile
accordingly).
If drawmap behaves the same, then submit a ticket with your data file
along with the mapfile for tracking down the problem.
Best regards,
Tamas
2007/10/17, Fanda <zerosgm at gmail.com>:
> I am using the latest version of mapserver (ms4w 2.2.6), c# mapscript. I
> don't know exactly what inline layer means, but I don't think that's the
> case of my layer. I've attached the whole mapfile to this message (the point
> layer is the very last one called 'Vrty'). It shows up in full extent, but
> as I pan or zoom so that any point of the layer is outside the current
> extent, the whole layer disappears.
> Best regards,
> Fanda
> Tamas Szekeres wrote:
> > Hi,
> > It would be helpful to post the entire mapfile you have. Are you using
> > an inline layer as the point layer?
> > Which projection you use with your map? What is the mapserver version?
> > Best regards,
> > Tamas
> > 2007/10/16, Fanda <zerosgm at gmail.com>:
> >> Hi all,
> >> I am facing really odd problem. I have some line and polygon layers in my
> >> mapfile and everything goes fine with them. But there is also one POINT
> >> layer and it shows up only in its full extent. If I zoom in or pan the
> >> layer
> >> disappears whereas the other layers are still visible as expected. There
> >> is
> >> no max/minscale defined. I am using C# mapscript. The definition of the
> >> layer in the mapfile is as follows:
> >>   LAYER
> >>     NAME                Vrty
> >>     STATUS      ON
> >>     TYPE                POINT
> >>     DATA                "vrty"
> >>     TOLERANCE   1
> >>     CLASS
> >>       NAME                      'vrty'
> >>       STYLE
> >>         SYMBOL          'circle'
> >>         SIZE            20
> >>         COLOR           255 0 0
> >>       END
> >>     END
> >>     PROJECTION
> >>       "init=epsg:2065"
> >>     END
> >>   END
> >> Any help would be greatly appreciated,
> >> Fanda
> >> View this message in context:
> >> http://www.nabble.com/mapscript-point-layer-zooming-tf4632685.html#a13229010
> >> Sent from the Mapserver - User mailing list archive at Nabble.com.
> http://www.nabble.com/file/p13247791/mapa.map mapa.map
> View this message in context: http://www.nabble.com/mapscript-point-layer-zooming-tf4632685.html#a13247791
