Question about Labels
    Jelmer Baas
    jelmerbs at XS4ALL.NL
    Mon Sep 17 03:03:11 PDT 2007
Daniel Morissette wrote:
 > Jelmer Baas wrote:
 >> Thanks for your quick response. I tried to use OGR:LabelText, and it
 >> seems to work -- sometimes. For *some* layers I get this following,
 >> quite interesting, error:
 >> msDrawMap(): Image handling error. Failed to draw layer named 'topo'.
 >> msOGRGetValues(): OGR error. Invalid field index!?!
 > I checked in the code, and it seems that you'd get that error if
 > MapServer tries to read one of the OGR:Label* attributes on a feature
 > that does not have a label definition, or in the case of TAB files, on a
 > MapInfo object that is not a TEXT object.
 > I am realizing just now that this makes it impossible to use OGR:Label*
 > on a .TAB file that has mixed object types. I think it would be possible
 > to make MapServer handle this more gracefully, i.e. returning some
 > default values (text="", angle=0 and size=0) in cases where the object
 > is not of the right type.
Daniel,
I'm a bit embarrassed, but I just found out that most items I want to
show are not labels, but simply text objects. I've figured out that I
need to set the layer type to point (which is a bit dirty, since I need
to define each layer twice -- once as line and once as point. Are there
no other solutions?).
However, this produces a... hmmm... screwed up image. I hosted it at:
http://www.coconline.nl/mapserv.gif - wrong
http://www.coconline.nl/mapserv.png - good
As you can see, it only occurs when I use GIF as an output format. I was
using MapServer 4.8.3, just tried 5.0.0 beta4, same effect.
The bad thing is that I use a little trick to provide the things you see
as an overlay. As in, I have the normal map and on top of that I present
measurements and the so called "as built" and "topo" drawings... I need
GIF for this since that bloody IE thing can't handle transparent PNG
properly.
Any suggestions? I assume this is a bug in one of the libraries
MapServer uses, and I'd be happy to assist tracking it down.
If you want more information, might I suggest you contact me directly on
this email address?
Jelmer
More information about the MapServer-users
