[MAPSERVER-USERS] No Labels on PostGIS Layer
osprey44 haak at agintegrated.com
Mon Jun 23 17:35:43 EDT 2008
Yes, that particular ID should return a name of "Madison".  Also, I attempted
to use acres and that column also has a value.  I have labeled layers that
have come from shapefiles in nearly the same manner (minus the postgis
connection), and their labels print properly.
Paul Ramsey-3 wrote:
> You're restricting your result to field_in of 50204. Does that record
> have values for the field_name?
> On Jun 23, 2008, at 2:07 PM, osprey44 wrote:
>> I have a particular layer in which I cannot seem to display the
>> labels.  The
>> shape displays correctly.  I have tried multiple columns to use as the
>> label, but all do not show.  Below is the specific chunk of the map
>> file:
>> 	LAYER
>> 		NAME "field"
>> 		TYPE POLYGON
>> 		STATUS ON
>> 		CONNECTION "user=web password=apacheweb08 dbname=base_dev
>> host=localhost
>> port=5432"
>> 		CONNECTIONTYPE postgis
>> 		DATA "field_boundary from (select fb.field_id as field_id,
>> fb.field_id as
>> OID, fb.field_boundary as field_boundary, fb.acres as acres,
>> f.field_name as
>> field_name from field_boundary fb, fields f where
>> fb.field_id=f.field_id) as
>> field_boundary"
>> 		FILTER "field_id in ('50204')"
>> 		LABELITEM "field_name"
>> 		CLASS
>> 			STYLE
>> 				OUTLINECOLOR 255 0 0
>> 				COLOR -1 -1 -1
>> 				WIDTH 3
>> 			END
>> 			LABEL
>> 				TYPE TRUETYPE
>> 				FONT arial
>> 				SIZE 10
>> 				ANTIALIAS TRUE
>> 				COLOR 0 0 0
>> 				OUTLINECOLOR 0 0 0
>> 				POSITION AUTO
>> 			END
>> 		END
>> 		PROJECTION
>> 			"init=epsg:4326"
>> 		END
>> 		DEBUG ON
>> 	END
>> http://www.nabble.com/file/p18078514/fieldMap.jpg
>> View this message in context:
>> http://www.nabble.com/No-Labels-on-PostGIS-Layer-tp18078514p18078514.html
>> Sent from the Mapserver - User mailing list archive at Nabble.com.
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
> Paul Ramsey
> pramsey at cleverelephant.ca
> +1 250 885 0632
View this message in context: http://www.nabble.com/No-Labels-on-PostGIS-Layer-tp18078514p18079028.html
