[MAPSERVER-USERS] No Labels on PostGIS Layer
Paul Ramsey
pramsey at cleverelephant.ca
Mon Jun 23 19:28:30 EDT 2008
Work it back to basics. Does it work without the join? There's nothing
obviously wrong with your map entry, that I can eyeball.
P
On Mon, Jun 23, 2008 at 2:35 PM, osprey44 <haak at agintegrated.com> wrote:
> Yes, that particular ID should return a name of "Madison". Also, I attempted
> to use acres and that column also has a value. I have labeled layers that
> have come from shapefiles in nearly the same manner (minus the postgis
> connection), and their labels print properly.
> Paul Ramsey-3 wrote:
>> You're restricting your result to field_in of 50204. Does that record
>> have values for the field_name?
>> On Jun 23, 2008, at 2:07 PM, osprey44 wrote:
>>> I have a particular layer in which I cannot seem to display the
>>> labels. The
>>> shape displays correctly. I have tried multiple columns to use as the
>>> label, but all do not show. Below is the specific chunk of the map
>>> file:
>>> LAYER
>>> NAME "field"
>>> TYPE POLYGON
>>> STATUS ON
>>> CONNECTION "user=web password=apacheweb08 dbname=base_dev
>>> host=localhost
>>> port=5432"
>>> CONNECTIONTYPE postgis
>>> DATA "field_boundary from (select fb.field_id as field_id,
>>> fb.field_id as
>>> OID, fb.field_boundary as field_boundary, fb.acres as acres,
>>> f.field_name as
>>> field_name from field_boundary fb, fields f where
>>> fb.field_id=f.field_id) as
>>> field_boundary"
>>> FILTER "field_id in ('50204')"
>>> LABELITEM "field_name"
>>> CLASS
>>> STYLE
>>> OUTLINECOLOR 255 0 0
>>> COLOR -1 -1 -1
>>> WIDTH 3
>>> END
>>> LABEL
>>> TYPE TRUETYPE
>>> FONT arial
>>> SIZE 10
>>> ANTIALIAS TRUE
>>> COLOR 0 0 0
>>> OUTLINECOLOR 0 0 0
>>> POSITION AUTO
>>> END
>>> END
>>> PROJECTION
>>> "init=epsg:4326"
>>> END
>>> DEBUG ON
>>> END
>>> http://www.nabble.com/file/p18078514/fieldMap.jpg
>>> View this message in context:
>>> http://www.nabble.com/No-Labels-on-PostGIS-Layer-tp18078514p18078514.html
>>> Sent from the Mapserver - User mailing list archive at Nabble.com.
>>> mapserver-users mailing list
>>> mapserver-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
>> Paul Ramsey
>> +1 250 885 0632
> View this message in context: http://www.nabble.com/No-Labels-on-PostGIS-Layer-tp18078514p18079028.html
