[MAPSERVER-USERS] No Labels on PostGIS Layer
osprey44 haak at agintegrated.com
Mon Jun 23 21:31:40 EDT 2008
Paul,
I originally started with just trying to view acres, which lives in
field_boundary table which has the geometry.  To triple check, I just
removed reference to the field table and changed the labelitem to "acres".
Still no joy.  Is there any special DB setting that is required to return
the label query data; similar to what needs to be done to utilize the
geometry columns?
Chris
Work it back to basics. Does it work without the join? There's nothing
obviously wrong with your map entry, that I can eyeball.
P
On Mon, Jun 23, 2008 at 2:35 PM, osprey44 <haak at agintegrated.com> wrote:
> Yes, that particular ID should return a name of "Madison".  Also, I
> attempted
> to use acres and that column also has a value.  I have labeled layers that
> have come from shapefiles in nearly the same manner (minus the postgis
> connection), and their labels print properly.
View this message in context: http://www.nabble.com/No-Labels-on-PostGIS-Layer-tp18078514p18081915.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
