[MAPSERVER-USERS] No Labels on PostGIS Layer
Paul Ramsey pramsey at cleverelephant.ca
Mon Jun 23 23:31:48 EDT 2008
There's really nothing special going on. Send your map file and a
table dump and I will attempt to duplicate, but frankly... if it was a
general problem we'd have heard of it by now.
P.
On Mon, Jun 23, 2008 at 6:31 PM, osprey44 <haak at agintegrated.com> wrote:
> Paul,
> I originally started with just trying to view acres, which lives in
> field_boundary table which has the geometry.  To triple check, I just
> removed reference to the field table and changed the labelitem to "acres".
> Still no joy.  Is there any special DB setting that is required to return
> the label query data; similar to what needs to be done to utilize the
> geometry columns?
> Chris
> Work it back to basics. Does it work without the join? There's nothing
> obviously wrong with your map entry, that I can eyeball.
> P
> On Mon, Jun 23, 2008 at 2:35 PM, osprey44 <haak at agintegrated.com> wrote:
>> Yes, that particular ID should return a name of "Madison".  Also, I
>> attempted
>> to use acres and that column also has a value.  I have labeled layers that
>> have come from shapefiles in nearly the same manner (minus the postgis
>> connection), and their labels print properly.
> View this message in context: http://www.nabble.com/No-Labels-on-PostGIS-Layer-tp18078514p18081915.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
> mapserver-users at lists.osgeo.org
