[mapserver-users] PostGis not displayed byMapServer
Burgholzer,Robert
rwburgholzer at deq.virginia.gov
Thu May 1 12:57:09 EDT 2008
Susanne,
Many things can go wrong with your postgis layer, I have two suggestions
that may get you moving on your way though:
1) Turn on the DEBUG and look at the PostGIS call on your layer. In
MS5+ this is done by including the following in your MAP definition (top
of mapfile, you choose the logfile name of course):
DEBUG ON
CONFIG "MS_ERRORFILE" "C:\Temp\mapserver.log"
And then "DEBUG ON" in your layer.
2) I notice there is no projection info on your MAP or your LAYER, I
always have that as an explicit declaration. i.e.:
PROJECTION
"init=epsg:4326"
END
Entries in both the MAP block and in the LAYER, where the epsg
corresponds to your projections.
HTH,
Robert W. Burgholzer
Surface Water Modeler
Office of Water Supply and Planning
Virginia Department of Environmental Quality
804-698-4405
Open Source Modeling Tools:
http://sourceforge.net/projects/npsource/
-----Original Message-----
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of
susanne.kalliany at tefis.at
Sent: Thursday, May 01, 2008 11:25 AM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] PostGis not displayed byMapServer
Hello to everyone,
I have an (already mentioned but - as it seems to me - not yet solved)
problem concerning PostGis used with MapServer.
My application can show shape files but not postgis-files. There are no
output files (png) generated for this layer.
Below is my mapfile.
I would be very pleased if anyone can give me some usefull hint.
Thanks a lot,
Susanne Kalliany
MAP
NAME global_map
STATUS ON
SIZE 1000 700
EXTENT -100300 260500 -99100 261600
UNITS meters
IMAGECOLOR 255 255 255
IMAGETYPE png24
WEB
IMAGEPATH "C:\ms4w\Apache\htdocs\tmp"
IMAGEURL "/tmp/"
END
LAYER
NAME Ortho
GROUP Ortho
DATA "C:\ms4w\Apache\htdocs\ortho\alle_e_50cm.tif"
projection
"AUTO"
end
TYPE RASTER
MINSCALE 10
MAXSCALE 10001
STATUS ON
DUMP TRUE
END
LAYER
CONNECTIONTYPE postgis
NAME UAbt
GROUP UAbt
CONNECTION "user=postgres password=xxxxxxxx
dbname=tefisdb host=localhost port=5432"
STATUS ON
TYPE line
DATA "roads_geom from roads"
CLASS
SIZE 16
COLOR 0 0 255
END
DUMP TRUE
END
END
UAbt with or without
projection "AUTO"
DI. Susanne KALLIANY - susanne.kalliany at tefis.at
TeFiS - www.tefis.at
Technische und forstliche Informationssysteme
(Forstliche Software und GIS)
Mobiltelephon: +43 664 1424269
Telephon: +43 316 931746-0, Fax: -15
A-8010 Graz, Schillerstrasse 58
A-1040 Wien, Schaumburgergasse 11/13
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
