[mapserver-users] Layer always turn on (not possible to
activate/deactivate)
Emilio Ponce
yosoycore at gmail.com
Wed May 7 13:34:37 EDT 2008
Hi everyone, here's a newbie question:
I'm using mapserver with ka-map and I have different layers in a unique
mapfile. I want to set ONE of this layers always visible, without
possibility to turn off (deactivate) it. For this purpose I thought the
STATUS tag on this LAYER was the solution: Status DEFAULT to turn on this
layer permanently... but it didn't work.
This is the code of the always-turn-on layer:
LAYER
NAME "ambits"
METADATA
"DESCRIPTION" "Ámbitos catalanes"
END
GROUP "BASE"
TYPE LINE
STATUS DEFAULT
CONNECTIONTYPE postgis
CONNECTION "host=*** dbname=*** user=*** password=*** port=5432
options='-c client_encoding=LATIN1'"
DATA "the_geom from car_aft_line"
CLASS
NAME 'Ambits'
COLOR 143 143 143
END
END
With this code I can turn on/turn off this layer... so what's the problem?
(the other layers seems to behave properly well)
Thanks a lot!
Emilio
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080507/fdccf008/attachment.html
