[mapserver-users] testing mapserver large files rendering
improvements
Jeff McKenna
jeffmckenna at gmail.com
Thu May 15 09:46:23 EDT 2008
Hello, comments inline below:
On 15-May-08, at 9:27 AM, Guillaume Sueur wrote:
> Hi,
> I've just been doing few tests on mapserver trunk version to get an
> idea of how much the rendering of large shapefiles has been improved
> by paul's hacks on shx handler (http://blog.cleverelephant.ca/2008/04/see_30.html
> My shapefile is 1 208 668 features, 160 Mo for the .shp file itself
> with a .shx of 5.2 Mo
> here are the times for a 5x5 km map to be drawn with shp2img, in PNG
> (no AGG)
> NO QIX :
> mapserv 5.0.2 : 0.680 s
> mapserv trunk : 0.699 s (!)
> WITH QIX :
> mapserv 5.0.2 : 0.124 s
> mapserv trunk : 0.027 s
> it looks like if the improvement only appears with use of a .qix
> file, which is highly recommended but sometimes forgotten.
> Has anyone had the same kind of experiment ?
yes: http://lists.osgeo.org/pipermail/mapserver-dev/2008-April/007170.html
> By the way, I noticed that it doesn't seem mandatory anymore to
> write the mapfile's DATA statement without the .shp extension to
> make use of the .qix file, as the results are strictly identical on
> mapserver trunk if I write "streets.shp" or "streets". Can someone
> confirm that ?
Confirmed. This was fixed recently (ticket: http://trac.osgeo.org/mapserver/ticket/590)
, verified, and documentation was updated. Therefore the next release
of MapServer will no longer require you to omit the '.shp' for the
DATA parameter for .qix use.
-jeff
