[mapserver-users] testing mapserver large files
rendering improvements
Guillaume Sueur
guillaume.sueur at neogeo-online.net
Thu May 15 10:09:47 EDT 2008
Thanks for theses informations Jeff.
I'd like to suggest to emphasis the need of a .qix file a little bit
more in the mapserver documentation. It's only explained in 'Utility
Programs' Section and 'Optimizing vector data sources' doc, but the huge
benefit of it (25 x faster in this case, but still 5x on small shapes)
is not, IMHO, mentionned enough to make people use it on every shapefile.
Regards,
Guillaume
Jeff McKenna a écrit :
> Hello, comments inline below:
> On 15-May-08, at 9:27 AM, Guillaume Sueur wrote:
>> Hi,
>> I've just been doing few tests on mapserver trunk version to get an
>> idea of how much the rendering of large shapefiles has been improved
>> by paul's hacks on shx handler
>> (http://blog.cleverelephant.ca/2008/04/see_30.html)
>> My shapefile is 1 208 668 features, 160 Mo for the .shp file itself
>> with a .shx of 5.2 Mo
>> here are the times for a 5x5 km map to be drawn with shp2img, in PNG
>> (no AGG)
>> NO QIX :
>> mapserv 5.0.2 : 0.680 s
>> mapserv trunk : 0.699 s (!)
>> WITH QIX :
>> mapserv 5.0.2 : 0.124 s
>> mapserv trunk : 0.027 s
>> it looks like if the improvement only appears with use of a .qix file,
>> which is highly recommended but sometimes forgotten.
>> Has anyone had the same kind of experiment ?
> yes: http://lists.osgeo.org/pipermail/mapserver-dev/2008-April/007170.html
>> By the way, I noticed that it doesn't seem mandatory anymore to write
>> the mapfile's DATA statement without the .shp extension to make use of
>> the .qix file, as the results are strictly identical on mapserver
>> trunk if I write "streets.shp" or "streets". Can someone confirm that ?
> Confirmed. This was fixed recently (ticket:
> http://trac.osgeo.org/mapserver/ticket/590), verified, and documentation
> was updated. Therefore the next release of MapServer will no longer
> require you to omit the '.shp' for the DATA parameter for .qix use.
> -jeff
> mapserver-users at lists.osgeo.org
