[mapserver-users] testing mapserver large files rendering
improvements
Paul Ramsey
pramsey at cleverelephant.ca
Thu May 15 10:43:08 EDT 2008
I've been thinking about auto-building qix files... it would fix this
problem and also fix the problem of the shape file that gets updated
and out-of-synch with its index file.
I think programmers will hate the idea, but users, maybe they will
like it? What do you think?
On Thu, May 15, 2008 at 7:09 AM, Guillaume Sueur
<guillaume.sueur at neogeo-online.net> wrote:
> Thanks for theses informations Jeff.
> I'd like to suggest to emphasis the need of a .qix file a little bit more in
> the mapserver documentation. It's only explained in 'Utility Programs'
> Section and 'Optimizing vector data sources' doc, but the huge benefit of it
> (25 x faster in this case, but still 5x on small shapes) is not, IMHO,
> mentionned enough to make people use it on every shapefile.
> Regards,
> Guillaume
> Jeff McKenna a écrit :
>> Hello, comments inline below:
>> On 15-May-08, at 9:27 AM, Guillaume Sueur wrote:
>>> Hi,
>>> I've just been doing few tests on mapserver trunk version to get an idea
>>> of how much the rendering of large shapefiles has been improved by paul's
>>> hacks on shx handler (http://blog.cleverelephant.ca/2008/04/see_30.html)
>>> My shapefile is 1 208 668 features, 160 Mo for the .shp file itself with
>>> a .shx of 5.2 Mo
>>> here are the times for a 5x5 km map to be drawn with shp2img, in PNG (no
>>> AGG)
>>> NO QIX :
>>> mapserv 5.0.2 : 0.680 s
>>> mapserv trunk : 0.699 s (!)
>>> WITH QIX :
>>> mapserv 5.0.2 : 0.124 s
>>> mapserv trunk : 0.027 s
>>> it looks like if the improvement only appears with use of a .qix file,
>>> which is highly recommended but sometimes forgotten.
>>> Has anyone had the same kind of experiment ?
>> yes: http://lists.osgeo.org/pipermail/mapserver-dev/2008-April/007170.html
>>> By the way, I noticed that it doesn't seem mandatory anymore to write the
>>> mapfile's DATA statement without the .shp extension to make use of the .qix
>>> file, as the results are strictly identical on mapserver trunk if I write
>>> "streets.shp" or "streets". Can someone confirm that ?
>> Confirmed. This was fixed recently (ticket:
>> http://trac.osgeo.org/mapserver/ticket/590), verified, and documentation was
>> updated. Therefore the next release of MapServer will no longer require you
>> to omit the '.shp' for the DATA parameter for .qix use.
>> -jeff
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
