[mapserver-users] testing mapserver large files rendering improvements
Kristian Thy thy at 42.dk
Thu May 15 11:00:22 EDT 2008
On Thu, May 15, Paul Ramsey wrote:
> I've been thinking about auto-building qix files... it would fix this
> problem and also fix the problem of the shape file that gets updated
> and out-of-synch with its index file.
Seeing that this would probably lead to (slightly) decreased performance
since mapserver-cgi would need to verify the qix for each shapefile for
each request, I would at least encourage adding it as a map file option
(default off).
Then again, you wouldn't get the benefit of it if you don't read the
docs, which is the problem you're trying to fix ;)
\\kristian
... et nemo ex vobis interrogat me: »Quo vadis?«
