[mapserver-users] Postgis Error
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Tue May 27 07:28:25 EDT 2008
Have you also registered the view in geometry_columns?
-Jukka Rahkonen-
Lähettäjä: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] Puolesta Aaron Hunt
Lähetetty: 27. toukokuuta 2008 14:25
Vastaanottaja: mapserver-users at lists.osgeo.org
Aihe: [mapserver-users] Postgis Error
I have been tring to get a script working on my new server and I get the following error.
"Postgresql reports the error as 'ERROR: relation "row_crop_boundary" does not exist '"
row_crop_boundary is a view contaning the geom column. There are no uppercaes names and if I log into the command line it works fine. Does anyone have any ideas? The layer def is below (I seet the data and filter in code).
Thanks
LAYER # Red Field
TYPE polygon
CONNECTIONTYPE postgis
NAME RedFields
CONNECTION "user=xxxpassword=xxx dbname=xxx host=localhost port=5432"
DATA ""
FILTER ""
STATUS ON
DEBUG ON
TRANSPARENCY 30
LABELITEM field_name
CLASS
COLOR 255 0 0
OUTLINECOLOR 0 0 0
LABEL
ANTIALIAS TRUE
FORCE TRUE
POSITION CC
BACKGROUNDCOLOR 75 75 75
COLOR 255 255 255
BUFFER 1
END
END
PROJECTION
"init=epsg:4326" #NAD83 UTM zone 10N
END
END
Aaron D. Hunt
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080527/42710d81/attachment-0001.html
