[mapserver-users] Postgis Error
Obe, Regina
robe.dnd at cityofboston.gov
Tue May 27 08:16:27 EDT 2008
Aaron,
Actually I don't think you need it in the geometry_columns if you spell out the whole USING UNIQUE bit.
What exactly does your data layer look like - all I see is
Data ""
Which can't be right.
Are you using the same account in Mapserver as you are using in your command line. Although permission problems usually give an access denied not a relation does not exist
Dumb questions -
you are absolutely sure you are connecting to the same database.
Your table is in the default schema or you have the schema spelled out in your Mapserver data layer.
Hope that helps,
Regina
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Rahkonen Jukka
Sent: Tuesday, May 27, 2008 7:28 AM
To: Aaron Hunt; mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] Postgis Error
Have you also registered the view in geometry_columns?
-Jukka Rahkonen-
Lähettäjä: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] Puolesta Aaron Hunt
Lähetetty: 27. toukokuuta 2008 14:25
Vastaanottaja: mapserver-users at lists.osgeo.org
Aihe: [mapserver-users] Postgis Error
I have been tring to get a script working on my new server and I get the following error.
"Postgresql reports the error as 'ERROR: relation "row_crop_boundary" does not exist '"
row_crop_boundary is a view contaning the geom column. There are no uppercaes names and if I log into the command line it works fine. Does anyone have any ideas? The layer def is below (I seet the data and filter in code).
Thanks
LAYER # Red Field
TYPE polygon
CONNECTIONTYPE postgis
NAME RedFields
CONNECTION "user=xxxpassword=xxx dbname=xxx host=localhost port=5432"
DATA ""
FILTER ""
STATUS ON
DEBUG ON
TRANSPARENCY 30
LABELITEM field_name
CLASS
COLOR 255 0 0
OUTLINECOLOR 0 0 0
LABEL
ANTIALIAS TRUE
FORCE TRUE
POSITION CC
BACKGROUNDCOLOR 75 75 75
COLOR 255 255 255
BUFFER 1
END
END
PROJECTION
"init=epsg:4326" #NAD83 UTM zone 10N
END
END
Aaron D. Hunt
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080527/e0579e2b/attachment.html
