[MAPSERVER-USERS] Postgis Error
Ritesh Ambastha group.ritesh at gmail.com
Tue May 27 10:20:03 EDT 2008
Dear Aaron,
Please check your DATA path.
It should be something like :   DATA "geom from your_table_name"
Hope this will help.
Regards,
Ambastha
Aaron Hunt-2 wrote:
> I have been tring to get a script working on my new server and I get the
> following error.
> "Postgresql reports the error as 'ERROR: relation "row_crop_boundary" does
> not exist '"
> row_crop_boundary is a view contaning the geom column. There are no
> uppercaes names and if I log into the command line it works fine. Does
> anyone have any ideas? The layer def is below (I seet the data and filter
> in
> code).
> Thanks
> LAYER # Red Field
>      TYPE           polygon
>      CONNECTIONTYPE postgis
>      NAME          RedFields
>      CONNECTION    "user=xxxpassword=xxx dbname=xxx host=localhost
> port=5432"
>      DATA          ""
>      FILTER        ""
>      STATUS        ON
>      DEBUG         ON
>      TRANSPARENCY  30
>      LABELITEM field_name
>      CLASS
>  COLOR 255 0 0
>  OUTLINECOLOR 0 0 0
>  LABEL
>   ANTIALIAS  TRUE
>   FORCE    TRUE
>   POSITION   CC
>   BACKGROUNDCOLOR 75 75 75
>   COLOR 255 255 255
>   BUFFER 1
>  END
>      END
>     PROJECTION
>       "init=epsg:4326" #NAD83 UTM zone 10N
>     END
>   END
> Aaron D. Hunt
> mapserver-users at lists.osgeo.org
View this message in context: http://www.nabble.com/Postgis-Error-tp17488191p17491542.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
