[mapserver-users] Replacing EMPTY parameter by CGI
Steve Lime Steve.Lime at dnr.state.mn.us
Tue May 27 18:05:01 EDT 2008
That's what's going on. If you file a quick bug I'll make sure that gets fixed in 5.2 which should be out relatively soon. BTW The
fix is to change line 164 in maplexer.l from:
<INITIAL>empty...
to:
<INITIAL,URL_STRING>empty...
Steve
>>> On 5/27/2008 at 5:48 AM, in message
<CPSMTP-EML102gmYGXj0007b4d5 at cpsmtp-eml102.kpnxchange.com>, "Wim Blanken"
<w.blanken at geon.nl> wrote:
> Hello List!,
> I'm having a problem with mapserver 5. In my former application using 4.x I
> was able to change the EMPTY Path in my application using the:
> &map_web_empty=path
> variable through CGI.
> I have changed this to the new method: &map_web=EMPTY+path
> Mapserver gives me an error: loadWeb(): Unknown identifier. Parsing error
> near (EMPTY):(line 1)
> I can change the HEADER template etc. using the same method
> (map_web=HEADER+path) but the empty parameter cannot be changed.
> Is it no longer possible to change the empty template through CGI with
> mapserver 5?
> Regards,
> Wim Blanken
> The Netherlands
> mapserver-users at lists.osgeo.org
