[mapserver-users] Replacing EMPTY parameter by CGI
Paul Ramsey
pramsey at cleverelephant.ca
Tue May 27 18:08:00 EDT 2008
Any reason not to patch 5.0?
P
On Tue, May 27, 2008 at 3:05 PM, Steve Lime <Steve.Lime at dnr.state.mn.us> wrote:
> That's what's going on. If you file a quick bug I'll make sure that gets fixed in 5.2 which should be out relatively soon. BTW The
> fix is to change line 164 in maplexer.l from:
> <INITIAL>empty...
> to:
> <INITIAL,URL_STRING>empty...
> Steve
>>>> On 5/27/2008 at 5:48 AM, in message
> <CPSMTP-EML102gmYGXj0007b4d5 at cpsmtp-eml102.kpnxchange.com>, "Wim Blanken"
> <w.blanken at geon.nl> wrote:
>> Hello List!,
>> I'm having a problem with mapserver 5. In my former application using 4.x I
>> was able to change the EMPTY Path in my application using the:
>> &map_web_empty=path
>> variable through CGI.
>> I have changed this to the new method: &map_web=EMPTY+path
>> Mapserver gives me an error: loadWeb(): Unknown identifier. Parsing error
>> near (EMPTY):(line 1)
>> I can change the HEADER template etc. using the same method
>> (map_web=HEADER+path) but the empty parameter cannot be changed.
>> Is it no longer possible to change the empty template through CGI with
>> mapserver 5?
>> Regards,
>> Wim Blanken
>> The Netherlands
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
