[mapserver-users] queryByAttributes on PostGIS-Layer
schroeter at netgis.de
Thu May 29 02:55:20 EDT 2008
Found the problem (thanks to Nicol ;-)
Code:
@$myQuery = $layer->queryByAttributes('nr_','7', MS_SINGLE);
must be changed to:
@$myQuery = $layer->queryByAttributes('nr_','nr_=7', MS_SINGLE);
Is this a bug?
Sven
----- Original Message -----
To: <mapserver-users at lists.osgeo.org>
Sent: Wednesday, May 28, 2008 12:48 PM
Subject: [mapserver-users] queryByAttributes on PostGIS-Layer
> Hallo list,
> My test-system: Mapserver 5.02 on WinXP and postgreSQL 8.2
> I try to make some querys via php-mapscript for a postgis-layer:
> queryByPoint,queryByShape and queryByRect is no problem.
> queryByAttributes always return "no result" (field 'nr_' is an integer)
> If I use a shapefile for the same data (biogasanlagen.shp)
> queryByAttributes works fine.
> mapfile:
> LAYER
> NAME "biogasanlagen"
> TYPE point
> STATUS on
> CONNECTIONTYPE postgis
> CONNECTION "user=postgres password=xyz dbname=mydb host=localhost
> port=5432"
> DATA "the_geom from biogasanlagen using unique gid"
> #DATA biogasanlagen.shp
> TEMPLATE void
> CLASS
> Name "biogasanlagen"
> OUTLINECOLOR 128 70 0
> COLOR 230 70 0
> SYMBOL 'circle'
> SIZE 12
> END # CLASS
> TRANSPARENCY 88
> TOLERANCE 8
> END
> php-Code:
> $layer = $map->getLayerByName("biogasanlagen");
> any idea?
> Thanks Sven
