[mapserver-users] queryByAttributes on PostGIS-Layer
Paul Ramsey
pramsey at cleverelephant.ca
Thu May 29 11:06:41 EDT 2008
Well, if it's presenting a markedly different API than a query on
shape file, I'd say it is at minimum non-optimal and worthy of a
ticket. Of course, at this late date, "fixing" it will break everyone
else's code... oh, dear :)
P
On Wed, May 28, 2008 at 11:55 PM, <schroeter at netgis.de> wrote:
> Found the problem (thanks to Nicol ;-)
> Code:
> @$myQuery = $layer->queryByAttributes('nr_','7', MS_SINGLE);
> must be changed to:
> @$myQuery = $layer->queryByAttributes('nr_','nr_=7', MS_SINGLE);
> Is this a bug?
> Sven
> ----- Original Message ----- From: <schroeter at netgis.de>
> To: <mapserver-users at lists.osgeo.org>
> Sent: Wednesday, May 28, 2008 12:48 PM
> Subject: [mapserver-users] queryByAttributes on PostGIS-Layer
>> Hallo list,
>> My test-system: Mapserver 5.02 on WinXP and postgreSQL 8.2
>> I try to make some querys via php-mapscript for a postgis-layer:
>> queryByPoint,queryByShape and queryByRect is no problem.
>> queryByAttributes always return "no result" (field 'nr_' is an integer)
>> If I use a shapefile for the same data (biogasanlagen.shp)
>> queryByAttributes works fine.
>> mapfile:
>> LAYER
>> NAME "biogasanlagen"
>> TYPE point
>> STATUS on
>> CONNECTIONTYPE postgis
>> CONNECTION "user=postgres password=xyz dbname=mydb host=localhost
>> port=5432"
>> DATA "the_geom from biogasanlagen using unique gid"
>> #DATA biogasanlagen.shp
>> TEMPLATE void
>> CLASS
>> Name "biogasanlagen"
>> OUTLINECOLOR 128 70 0
>> COLOR 230 70 0
>> SYMBOL 'circle'
>> SIZE 12
>> END # CLASS
>> TRANSPARENCY 88
>> TOLERANCE 8
>> END
>> php-Code:
>> $layer = $map->getLayerByName("biogasanlagen");
>> any idea?
>> Thanks Sven
>> mapserver-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
