[mapserver-users] High CPU
Steve White steve at online-archaeology.co.uk
Fri Sep 5 15:03:58 EDT 2008
I'm running the latest version of MS4W on a virtual private server with the
following:
-          2003 Server
-          IIS 6.0
-          Intel Xeon CPU 3.20Ghz
-          640MB RAM
I have one shapefile 850KB and a basic mapfile like below:
MAP
  NAME        Test
  STATUS                                              ON
  UNITS                                                 METERS
  SHAPEPATH                                      "C:\Inetpub\scripts\data\"
  IMAGECOLOR                                  0 255 255
  SIZE                                                      400 400
  DEBUG                                                               ON
  IMAGETYPE                                      PNG
  EXTENT                                               -4.35 56.14 -3.23
56.91
WEB
  METADATA
    "wms_title"                                    "Test MS"
    "wms_onlineresource"             "http://localhost/scripts/mapserv.exe&"
    "wms_srs"                                      "EPSG:4326 EPSG:54004
EPSG:27700"
    "wms_feature_info_mime_type" "text/html"
  END
IMAGEPATH                                       "C:\Inetpub\wwwroot\tmp\"
IMAGEURL                                          "C:\Inetpub\wwwroot\tmp\"
LOG
"C:\Inetpub\wwwroot\tmp\mapserver.log"
TEMPLATE
"C:\Inetpub\wwwroot\Test\templates\template.html"
EMPTY
"C:\Inetpub\wwwroot\Test\templates\template_empty.html"
END
PROJECTION
  "init=epsg:4326"
END
SYMBOL
  NAME "circle"
  TYPE ellipse
  FILLED true
  POINTS
    1 1
  END
END
LAYER
                NAME                                                   Test
                METADATA
        "wms_title"                                                "Test"
                "gml_include_items"                     "all"
                "wms_include_items"                   "all"
                END
                TYPE
POINT
                DATA
Test
                STATUS
ON
                DUMP                                                   TRUE
        CLASS
                                TEMPLATE
"C:\Inetpub\wwwroot\Test\templates\template_test.html"
                STYLE
                                                SYMBOL "circle"
                                                SIZE 10
                                                COLOR 0 0 255
                END
        END
END #end of layer
END # end of mapfile
I'm sending WMS GetMap requests to the layer from my localhost and
monitoring CPU on the server.
Every time I send a request the server CPU hits 100% until the request ends.
1)      Is 640MB RAM enough to cope with this simple request?
2)      Is there anything wrong with the mapfile?
3)      Are there any methods I can use to tune this further?
Cheers,
Steve
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080905/8a0be3b5/attachment-0001.html
