[mapserver-users] Can't get any Results from a simple query
Thomasch
thomaschx at gmx.de
Thu Aug 20 13:25:03 EDT 2009
I'm quite new in Mapserver, so sorry for this simple question:
I use the Itasca Demo with my own little map, containing just a few
layers. The layers are displayed and labeld, so the connection is ok.
But, if I try to query an Object, i always get:
"msQueryByPoint(): Search returned no results. No matching record(s) found"
I think I should get the geomety data at least?
Here is the Layer part of my map file:
Code:
LAYER
NAME orte
DATA orte
STATUS ON
TYPE POLYGON
LABELITEM "orte"
CLASSITEM "orte"
METADATA
qstring_validation_pattern '.'
END
TOLERANCE 300
CLASS
NAME 'orte'
TEMPLATE "TP.html"
STYLE
COLOR 232 252 232
OUTLINECOLOR 32 32 32
END
LABEL
COLOR 0 0 0
SHADOWCOLOR 218 218 218
SHADOWSIZE 2 2
TYPE BITMAP
SIZE MEDIUM
POSITION CC
PARTIALS TRUE
BUFFER 2
END
END
END
Thanks in advance
Thomasch
