[mapserver-users] Status on ticket 2582?
Martin Kofahl m.kofahl at gmx.net
Sun Feb 22 12:44:14 EST 2009
Hi Alan,
the intention of #1952 (and #2582 !?) was to hide a layer only for
capabilities requests. E.g. in order to hide grouped layers with
different resolutions which shall be used only by the group name. So
getmap requests (e.g. using the group name) shall definitely work even
if a layer is hidden.
I think your work will prevent the layer to be served at all?!
Martin
Alan Boudreault wrote:
> I'm currently making a similar patch. I didn't see the ticket 1952
> before. It will use "[service]_dump" metadata. ie. "wms_dump" set to
> false (true by default) will disable this layer for all possible
> requests (not only the getcapabilities). It should be in 5.4 beta 2.
> Alan
> paalkr wrote:
>> Sorry! Didn't look at the patch prior to writing the comment. Obviously
>> Martin has taken care of all the service types. I see no reason why the
>> patch not should enter trunk (and 5.4 branch)  and become a part of the next
>> 5.4 beta.
>> Regards,
>> Pål Kristensen
>> paalkr wrote:
>>> @Devs; what about incorporating this patch into the core and finally fix
>>> the issue? I guess the remaining work is to apply support for other
>>> services than WMS (i.e. wfs, sos, wcs), and documentation of course :-)
>>> Regards,
>>> Pål Kristensen
>>> Martin Kofahl wrote:
>>>> Hi,
>>>> I did add a patch for ms540-b1 to ticket #1952
>>>> [http://trac.osgeo.org/mapserver/ticket/1952]. It uses a
>>>> ows_hidden_layer metadata and does also solve ticket #2582. It does also
>>>> work for layers grouped by using the wms_layer_group metadata and does
>>>> otherwise work as described i my last post.
>>>> Martin
