[mapserver-users] GeoJSON output from MapServer
Dejan.Gambin at pula.hr
Wed Jul 1 16:11:36 EDT 2009
Steve,
Here are more details, I am sure you'll have some further suggestions:
There is a project called GeoReport, part of GeoBI suite, that integrates
the data coming from Business Intelligence processes (Pentaho BI) with
their cartographic representation. Since I am pretty much involved in both
areas (WebGIS, BI), this seems very interesting to me, although I first
saw it yesterday :-(
Here are the main informations about GeoReport:
http://www.geobi.org/2009/01/georeport-module.html
As I can see, basically, there is a MapOL module that runs BI process in
order to get resultset, join it with geometries coming from GeoServer
(WFS) and returns GeoJSON data to WebGIS client (MapFish and OpenLayers +
Geostat widgets) which displays it on the map.
I have been in contact with Fabio (he is "responsible" for all this).
Based on what he said, I understood (maybe wrongly) that WFS server needs
to return GeoJSON, and GeoServer can do it. Now, as I write this to you,
it seems like MapOL is responsible for creating GeoJSON data ?!
Anyway, I am new to this almost as you and if you can take a look on above
link, I would appreciate it very much. I "only" want to use MapServer
instead of GeoServer. If I can't do it, then I'll rather do nothing as I
have no intentions to use anything but MapServer :-)
thanks very much
regards, dejan
"Steve Lime" <Steve.Lime at dnr.state.mn.us> wrote on 01.07.2009 16:36:48:
> Depends on how you need to access it. You certainly can create a
> template that will output GeoJSON. However,
> at the moment you can only access that output though calls to the
> CGI and (probably) MapScript. WMS and WFS
> do not recognize the template output format although there are plans
> to do so in the upcoming release.
> Let me know if I can help further...
> Steve
> >>> On 7/1/2009 at 7:44 AM, in message
> <OF425313EF.2215E677-ONC12575E6.004595DF-C12575E6.00460800 at pula.hr>,
> <Dejan.Gambin at pula.hr> wrote:
> > Hi,
> > Is it possible to use GeoJSON template for getting GeoJSON output from
> > MapServer? I have tried using outputformat as described in:
> > http://mapserver.org/development/rfc/ms-rfc-36.html and
> > http://mapserver.org/development/rfc/ms-rfc-56.html
> > Is it supported at all? I have a project where I need a GeoJSON
output.
> > This project originally uses GeoServer whcih has a plugin for this. Is
> > this possible with MapServer? I am using MapServer 5.4.1
> > thanks very much
> > regards, dejan
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090701/23a4fadd/attachment.html
