[mapserver-users] Object reference not set to an instance of
an object
Pano Voudouris
pvoudouris at gaiocorp.com
Thu Jul 9 12:48:06 EDT 2009
Hi Suman,
Check your web.config file- You probably have an entry similar to:
<appSettings>
<add key="mapfile" value="C:\ms4w\Apache\htdocs\...addison.map"/>
In your code you want to create the mapfile object by reading the mapfile
path from web.config. So what you need to do is:
mapObj map= new
mapObj(System.Configuration.ConfigurationManager.AppSettings["mapfile"].toSt
ring())
(or whatever the variable in the web.config is called)
You don't really want to use a constant to point to the mapfile...
Pano
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Suman
Chatterjee
Sent: 09 July 2009 17:50
To: Tamas Szekeres
Cc: mapserver-users at lists.osgeo.org
Subject: RE: [mapserver-users] Object reference not set to an instance of an
object
I corrected my problem. Actually, I changed the code a little bit.
Const string MAP_FILE = "c:/inetpub/wwwroot/Addison.map"
Map= new mapObj(MAP_FILE)
The line
System.Configuration.ConfigurationManager.AppSettings["C:/ms4w/Apache/htdocs
/mapservertest/Addison.map"]
Is throwing error. No idea what it is trying to do.
Now my application is working fine in IIS and C#.
Suman
-----Original Message-----
From: Tamas Szekeres [mailto:szekerest at gmail.com]
Sent: Wednesday, July 08, 2009 6:22 PM
To: Suman Chatterjee
Subject: Re: [mapserver-users] Object reference not set to an instance of an
object
Hi Suman,
I suspect
/mapservertest/Addison.map"] evaluates to null in your case, and therefore
the ToString() operation on the null reference is failing which problem is
not related to the MapScript library itself.
Best regards,
Tamas
2009/7/8 Suman Chatterjee <schatterjee at addisontx.gov>
Hi all,
I am trying to develop an application in C# (VS2005) with mapscript. I saw
the material of Paolo. But I am facing a problem
In the line
mapObj map= new
mapObj(System.Configuration.ConfigurationManager.AppSettings["C:/ms4w/Apache
/htdocs/mapservertest/Addison.map"].toString())
It is generating the error " Object reference not set to an instance of an
object"
How can I correct this? If anyone helps me in correcting it, it will be
great.
Suman
This e-mail and any files or attachments transmitted with it contains
Information that is confidential and privileged. This document may contain
Protected Health Information (PHI) or other information that is intended
only for the use of the individual(s) and entity(ies) to whom it is
addressed. If you are the intended recipient, further disclosures are
prohibited without proper authorization. If you are not the intended
recipient, any disclosure, copying, printing, or use of this information is
strictly prohibited and possibly a violation of federal or state law and
regulations. If you have received this information in error, please delete
it and notify Hamid Khaleghipour at 972-450-2868 immediately. Thank you.
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090709/73bec856/attachment.html
