[mapserver-users] Smaller polygon sizes when usingmapserver
5.4.1compare to 5.2.0
Thomas Bonfort
thomas.bonfort at camptocamp.com
Wed Jul 15 01:36:22 EDT 2009
the previous versions of mapserver (incorrectly I think) used the
value of the label buffer to expand the background billboard. You'd
get nice results whith a 1 or 2 px buffer like in your case, but
unusable ones when you added larger buffers.
I hope we can work around this for 5.6 with the possible label style rewrite.
regards,
thomas
www.camptocamp.com
+33 4 79 26 57 97
On Tue, Jul 14, 2009 at 03:01, Steve Lime<Steve.Lime at dnr.state.mn.us> wrote:
> Wonder if it's the same issue as with the polygon size you noted. Even though the shield
> is a rect it's rendered as a polygon. Thomas, should polygons be drawn with an outline
> same as the fill color if no outline color is specifiied?
> Steve
>>>> "Nikolai Nikolov" <nnikolov at gypsii.com> 07/09/09 2:43 AM >>>
> Hi Steve and everyone,
> The images below are from Mapserver 5.2.0 (left) and 5.4.1 (right) of the
> same map using AGG. Please note the difference in the size of the road
> shields (green shields).
> The following are images from the same servers (Mapserver 5.2.0 (left) and
> 5.4.1 (right)) of the same map (different zoom) using GD. Please note that
> the two maps are practically the same.
> The complete map-file used for the first example is attached to this e-mail.
> The parts of it specific to the issue are like that:
> OUTPUTFORMAT
> NAME AGG_PNG
> DRIVER AGG/PNG
> MIMETYPE "image/png"
> IMAGEMODE RGB
> EXTENSION "png"
> #FORMATOPTION "QUANTIZE_FORCE=TRUE"
> #FORMATOPTION "QUANTIZE_COLORS=256"
> FORMATOPTION "PALETTE_FORCE=TRUE"
> FORMATOPTION "PALETTE=/var/www/html/maps_gypsii/palette.txt"
> FORMATOPTION "INTERLACE=OFF"
> END
> and
> CLASS
> EXPRESSION /^E/
> LABEL
> PRIORITY 4
> PARTIALS false
> MINFEATURESIZE 10
> MINDISTANCE 300
> COLOR 255 255 255
> BACKGROUNDCOLOR 128 208 100
> BACKGROUNDSHADOWCOLOR 81 145 58
> ANGLE 0
> BUFFER 2
> FONT arial-bold
> TYPE truetype
> SIZE 7
> END
> END
> The difference for the second examples is in the output format used:
> OUTPUTFORMAT
> NAME PNG
> DRIVER GD/PNG
> IMAGEMODE RGB
> EXTENSION "png"
> END
> Many thanks,
> Nick
> -----Original Message-----
> From: Steve Lime [mailto:Steve.Lime at dnr.state.mn.us]
> Sent: 08 July 2009 15:29
> To: Nikolai Nikolov; mapserver-users at lists.osgeo.org
> Subject: Re: [mapserver-users] Smaller polygon sizes when usingmapserver
> Perhaps you could post image samples and a mapfile?
> Steve
>>>> On 7/8/2009 at 3:05 AM, in message
> <65D1C555BE9443A180F3B1697EF7E69F at BenefonUK.local>, "Nikolai Nikolov"
> <nnikolov at gypsii.com> wrote:
>> Hi everyone,
>> I've just upgraded one of my test servers from 5.2.0 to 5.4.1. I have an
>> issue there and I wonder whether anybody have noticed it. My map
> polygones
>> seems to be fractionaly smaller (compare to those drawned by 5.2.0).
>> I am using the same maps, map files, PHP scripts, etc. The plygons which
>> belong to the same layer, do not quite well "fit" with each other - their
>> borders match perfectly before the upgarde to 5.4.1.
>> Also, I use BACKGROUNDCOLOR in my map file to create shield like square
>> behind a label. Those squares are now significantly smaller too.
>> I wander what causes this effect and what I should do to achieve the same
>> image as with 5.2.0?
>> Thanks,
>> Nick
