[mapserver-users] msConvertWideStringToUTF8(): General error
message. Encoding not supported by libiconv (UTF-16LE)
Daniel Morissette
dmorissette at mapgears.com
Thu Jul 23 08:48:10 EDT 2009
Mr. Bic Phuong wrote:
> I hope someone can solve this problem, our project is delayed by this error.
> the GetFeatureInfo function is failed:
> msConvertWideStringToUTF8(): General error message. Encoding not supported
This error message is telling you that the libiconv library, which is
used by MapServer for encoding conversions, does not support UTF-16LE on
that server.
You need to find out which libiconv your Mapserver was compiled with and
then make sure that copy of libiconv has support for the UTF-16LE
encoding. You can list the encodings supported by libiconv on a given
system using "iconv -l"... make sure UTF-16LE is there.
> this error accured when I'm setting up a webgis on the second Red Hat
> Enterprise Linux (RHEL) 5.3, on the first RHEL 5.3, GetFeatureInfo is
> working perfect.
Look for a difference between the two servers related to libiconv.
Daniel
Daniel Morissette
http://www.mapgears.com/
