[mapserver-users] Importing a Google/Yahoo maps raster layer
Fawcett, David
David.Fawcett at state.mn.us
Mon Jun 1 09:53:31 EDT 2009
Take a look at OpenLayers. http://www.openlayers.org
Here is an example of an OpenLayers application that uses Google as the
base layer.
http://www.openlayers.org/dev/examples/sundials-spherical-mercator.html
(When the app first loads, it is using OpenStreetMap data as the base
layer. Click on the '+' icon on the right side of the map to expand the
layer switcher and you can then switch to a Google layer.)
You can also use Microsoft Virtual Earth data
And using MapServer, you can publish your data as a WMS and pull it in
to the same OpenLayers app. (You can also connect to MapServer with a
native MapServer CGI call, but the developers are encouraging the use of
a standard WMS call.)
David.
-----Original Message-----
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Adrian
Popa
Sent: Monday, June 01, 2009 4:16 AM
To: Rahkonen Jukka
Cc: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] Importing a Google/Yahoo maps
raster layer
Hello,
Thank you for your clarification. So, I would need the
client-side to support google/yahoo layers and mapserver would run to
feed just its specific layers.
Interesting.
Anyway, do you know any other projects that offer (with an open
license) access to raster satellite/aerial imagery that can be
integrated with mapserver?
Regards,
Adrian Popa
Rahkonen Jukka wrote:
Terms and conditions of these services do not allow
cascading
Google/Yahoo maps through Mapserver. However, it is
allowed to let the
mapping client to make this integration. One example I
found from my
bookmarks is here:
http://sautter.com/map/?zoom=5&lat=64.45292&lon=30&layers=B000TFFF
-Jukka Rahkonen
Adrian Popa wrote:
Hello everybody,
I'm not sure if it's been disscussed on the list
already or
not, but I wanted to ask if it's possible to
integrate
mapserver (and starting with which version?)
with Google/Yahoo maps.
I would like to display the raster (satellite)
images from
google/yahoo as a layer in the map. The thing is
- I don't
want to store the actual raster data on my
server - but to
make requests to google/yahoo on the fly.
Thank you,
Adrian Popa
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
Adrian Popa
NOC Division
Network Engineer
Divizia Centrul National de Operare Retea
Departament Transport IP & Metro
Compartiment IP Core & Backbone
Phone: +40 21 400 3099
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090601/e2901933/attachment.html
