[mapserver-users] Importing a Google/Yahoo maps raster layer
Adrian Popa
adrian_gh.popa at romtelecom.ro
Mon Jun 1 10:06:24 EDT 2009
Hello David,
Unfortunatelly I am tied into a different web presentation layer -
MsMap. It has some features (like marking locations at specific
coordinates and adding interactive options to them) and I can't abandon it.
I will look at openlayers, to see if it supports the functionality I need.
Thank you for your help.
Adrian Popa
Fawcett, David wrote:
> Take a look at OpenLayers. http://www.openlayers.org
> Here is an example of an OpenLayers application that uses Google as
> the base layer.
> http://www.openlayers.org/dev/examples/sundials-spherical-mercator.html
> (When the app first loads, it is using OpenStreetMap data as the base
> layer. Click on the '+' icon on the right side of the map to expand
> the layer switcher and you can then switch to a Google layer.)
> You can also use Microsoft Virtual Earth data
> And using MapServer, you can publish your data as a WMS and pull it in
> to the same OpenLayers app. (You can also connect to MapServer with a
> native MapServer CGI call, but the developers are encouraging the use
> of a standard WMS call.)
> David.
> -----Original Message-----
> *From:* mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] *On Behalf Of
> *Adrian Popa
> *Sent:* Monday, June 01, 2009 4:16 AM
> *To:* Rahkonen Jukka
> *Cc:* mapserver-users at lists.osgeo.org
> *Subject:* Re: [mapserver-users] Importing a Google/Yahoo maps
> raster layer
> Hello,
> Thank you for your clarification. So, I would need the client-side
> to support google/yahoo layers and mapserver would run to feed
> just its specific layers.
> Interesting.
> Anyway, do you know any other projects that offer (with an open
> license) access to raster satellite/aerial imagery that can be
> integrated with mapserver?
> Regards,
> Adrian Popa
> Rahkonen Jukka wrote:
>> Hi,
>> Terms and conditions of these services do not allow cascading
>> Google/Yahoo maps through Mapserver. However, it is allowed to let the
>> mapping client to make this integration. One example I found from my
>> bookmarks is here:
>> http://sautter.com/map/?zoom=5&lat=64.45292&lon=30&layers=B000TFFF
>> -Jukka Rahkonen
>> Adrian Popa wrote:
>>> Hello everybody,
>>> I'm not sure if it's been disscussed on the list already or
>>> not, but I wanted to ask if it's possible to integrate
>>> mapserver (and starting with which version?) with Google/Yahoo maps.
>>> I would like to display the raster (satellite) images from
>>> google/yahoo as a layer in the map. The thing is - I don't
>>> want to store the actual raster data on my server - but to
>>> make requests to google/yahoo on the fly.
>>> Thank you,
>>> Adrian Popa
>>> mapserver-users mailing list
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090601/334ab940/attachment-0001.html
