[mapserver-users] Mapserver/Windows x64 binaries
Tamas Szekeres
szekerest at gmail.com
Fri Mar 27 08:55:39 EDT 2009
I think you should try with my latest binaries, download the package which
suits best to your compiler/plaform.
http://vbkto.dyndns.org:1280/sdk/index.html
You could also download the latest SDKs from here in case if you'd create
your own compilation.
Best regards,
Tamas
2009/3/27 adsaero <ag at ads.aero>
> I'm wondering if anyone could help; I've been Googled 'till my fingers
> bled, and I haven't had much success in finding anyone else who has managed
> to get the Mapserver to run in native x64 mode on an x64 Windows (2008) box.
> I saw this post;
> http://www.mail-archive.com/mapserver-users@lists.umn.edu/msg15162.html
> And even downloaded the binaries from there, but I still get errors when
> trying to run my mapscript app. First, I was getting "SideBySide" errors:
> Activation context generation failed for
> "C:\inetpub\map\wms3\bin\libpng13d.dll". Dependent Assembly
> Microsoft.VC80.DebugCRT,processorArchitecture="amd64",publicKeyToken="1fc8b3b9a1e18e3b",type="win32",version="8.0.50608.0"
> could not be found. Please use sxstrace.exe for detailed diagnosis.
> Then after checking out some posts, I tried copying some Visual Studio
> binaries into the app's bin directory. That produced some different yet
> less helpful results:
> Exception information:
> Exception type: HttpException
> Exception message: The specified module could not be found. (Exception
> from HRESULT: 0x8007007E)
> With no clues as to what the specified module was.
> We need to run the Mapserver with x64 native code because code that works
> with the mapscript (which we need to reside on the same machine) runs in
> native x64 to take advantage of the larger memory.
> Can anyone offer some good pointers or suggestions for getting Mapscript to
> run in native x64 mode?
> http://n2.nabble.com/Mapserver-Windows-x64-binaries-tp2544032p2544032.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
> mapserver-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090327/d21f1744/attachment-0001.html
