[mapserver-users] Mapserver returns part of an image and then
crashes
Tamas Szekeres
szekerest at gmail.com
Fri May 15 18:01:53 EDT 2009
Nelson,
The information you've provided is not enough to find out the problem. You
should probaly localize which layers/features cause this problem and extract
a subset of the data to be able to reproduce it.
You could use ogr2ogr and specify the -spat option to copy the relevant data
into a new data source.
Best regards,
Tamas
2009/5/15 Nelson Correia <nelsonwc7 at hotmail.com>
> Hi,
> Have anyone ran through the same problem?
> Any ideas on how to solve it?
> Thanks,
> Nelson
> From: nelsonwc7 at hotmail.com
> To: szekerest at gmail.com
> Subject: RE: [mapserver-users] Mapserver returns part of an image and then
> crashes
> Date: Fri, 24 Apr 2009 17:28:53 +0000
> CC: mapserver-users at lists.osgeo.org
> Hi,
> I am using ms4w 2.3.1.
> Unfortunately it is a large data set and a huge map file, that I am not
> able to send, sorry.
> Thanks,
> Nelson
> Date: Fri, 24 Apr 2009 19:20:44 +0200
> Subject: Re: [mapserver-users] Mapserver returns part of an image and then
> crashes
> From: szekerest at gmail.com
> To: nelsonwc7 at hotmail.com
> Which binaries are you using?
> Could you provide the sample data with a mapfile to repoduce it?
> Best regards,
> Tamas
> 2009/4/24 Nelson Correia <nelsonwc7 at hotmail.com>
> Hi,
> I am using mapserver on windows, and recently, after a few changes in my
> configuration, it started crashing (only for some bounding boxes - some
> areas of the map are returned without problem), without returning an error
> message. It returns only part of the image, but then the mapserver process
> crashes with the following information:
> *Problem signature:
> *Problem Event Name: APPCRASH
> Application Name: mapserv.exe
> Application Version: 0.0.0.0
> Application Timestamp: 4935ad86
> Fault Module Name: ntdll.dll
> Fault Module Version: 6.0.6001.18000
> Fault Module Timestamp: 4791a783
> Exception Code: c0000005
> Exception Offset: 0002f8f4
> OS Version: 6.0.6001.2.1.0.272.7
> Locale ID: 2070
> Additional Information 1: c997
> Additional Information 2: ae645009e6c492243309385fb187f9cb
> Additional Information 3: 8219
> Additional Information 4: b67578da7791af77bcf37b260b2c58a9
> I reverted the changes I've made to a configuration that worked before, but
> I am no longer able to run it properly, it crashes all the time for certain
> zones of the map.
> Any ideas?
> Thanks,
> Nelson
> Get news, entertainment and everything you care about at Live.com. Check
> it out! <http://www.live.com/getstarted.aspx>
> check out the rest of the Windows Live™. More than mail–Windows Live™ goes
> way beyond your inbox. More than messages<http://www.microsoft.com/windows/windowslive/>
> Invite your mail contacts to join your friends list with Windows Live
> Spaces. It's easy! Try it!<http://spaces.live.com/spacesapi.aspx?wx_action=create&wx_url=/friends.aspx&mkt=en-us>
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090516/1cfc1674/attachment.html
