[mapserver-users] RE: fixed label size in map units [SOLVED]
deduikertjes
DeDuikertjes at xs4all.nl
Fri Apr 16 07:20:15 EDT 2010
Ok, I seem to have found it in the archives:
"You need to set a SYMBOLSCALE at the layer level. That's the scale
denominator (e.g. 100000) at which a label SIZE will be equal to what you
set in the mapfile. As you move away from that value
the labels will get larger or smaller.
Indeed I've put SYMBOLSCALE 1000 in the layer object and SIZE 6 in the LABEL
object, and now the labels stay the same size when measured in map units.
All I have to find out is the relation between SYMBOLSCALE SIZE and the map
units.
Thank for help.
MArco
View this message in context: http://n2.nabble.com/fixed-label-size-in-map-units-tp4903182p4912399.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
