[mapserver-users] Premature end of script headers: mapserv
Shaz N
geo.engineer123 at gmail.com
Sat Jan 9 13:28:09 EST 2010
Hi..
It works with shp2img. I got the png file and it was perfect.
The wms request doesnt work and thats when I get the error. I am sorry to
sound confused but I am not sure about how to proceed. Should I set DEBUG ON
in all my layers? What else do I do? Please help.
Thanks.
On Sat, Jan 9, 2010 at 4:45 PM, Dan Little <danlittle at yahoo.com> wrote:
> Try testing it with shp2img and see if you still get the same error.
> Also, you may need to try the whole thing under GDB or with debugging
> turned on.
> *From:* Shaz N <geo.engineer123 at gmail.com>
> *To:* mapserver-users at lists.osgeo.org
> *Sent:* Fri, January 8, 2010 11:27:12 PM
> *Subject:* [mapserver-users] Premature end of script headers: mapserv
> Hi users..
> I have been adding a few new shapefiles to my existing map file. I am a
> facing a new problem since last evening. I added 9 shapefiles successfully
> and could view the map in the browser. While adding the 10th shapefile I got
> an error. All the new shapefiles are simple point shapefiles.
> Example: LAYER
> NAME 'sc'
> CONNECTIONTYPE postgis
> CONNECTION " "
> DATA "the_geom from sc"
> TEMPLATE "dummy.html"
> DEBUG ON
> TYPE POINT
> MAXSCALE 10000
> MINSCALE 2000
> STATUS DEFAULT
> LABELITEM "name"
> LABELCACHE ON
> CLASS
> MAXSCALE 10000
> MINSCALE 2000
> STYLE
> ANTIALIAS TRUE
> SYMBOL "square"
> SIZE 9
> COLOR 153 0 102
> OUTLINECOLOR 255 255 255
> END #end style
> LABEL
> ANGLE auto
> COLOR 153 0 102
> ANTIALIAS TRUE
> FONT vera_sans-bold
> TYPE TRUETYPE
> SIZE 9
> POSITION auto
> PARTIALS false
> BUFFER 1
> END #end label
> END#end class
> END #end layer
> This is the error from the error log:
> And this is what I got using WMS get map request on the browser:
> Internal Server Error
> The server encountered an internal error or misconfiguration and was unable
> to complete your request.
> Please contact the server administrator, [no address given] and inform them
> of the time the error occurred, and anything you might have done that may
> have caused the error.
> More information about this error may be available in the server error log.
> I checked the shapefile and map file for errors and couldn’t find any. And
> mapserver has been installed correctly and has been working well. The
> problem only arises when I add the extra layer. It works well with all the
> existing ones.
> The map file works on my PHP map display page but when I try it using WMS
> it does not work.
> I use MapServer 5.0.
> Any help would be greatly appreciated.
> Thanks in advance.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100109/0ac099da/attachment.html
